7 members (Deegs53, 78buckshot, Gray_Ghost, Wheelie, Otto Skorzeny, Gdads51, TUTS 59),
198
Mod | | | Forums66 Topics128,078 Posts1,056,022 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2005 Posts: 738 Shop Shark | | Shop Shark Joined: Oct 2005 Posts: 738 | There is a little knob with a "T" on it on the dash of my 61 chevy. It used to work as a kind of hillbilly cruise control, until it stopped working. I actually used it more to warm the truck up than anything else, I would put the gas pedal down a touch and lock it and let the thing warm up. A month or o ago it quit working. Is this knob a driect cable assembly? Meaning when I pull the knob does it literally lock the carb in position, or is it attatched to the gas pedal. I would like to fix it because it worked as an effective cruise control on flat ground and was a nice tool to warm the old truk up without sitting in it. Thoughts, ideas, verbal abuse, all welcome.
"Never tell people how to do things. Tell them what to do and they will surprise you with their ingenuity." - George S. Patton My Machine | | | | | Joined: Feb 2006 Posts: 2 Junior Member | | Junior Member Joined: Feb 2006 Posts: 2 | sounds to me like a throttle control like on a tow truck. We just put one on. Does your truck have an extra cable running to the carb? MY does. You pull it and turn it 90 degrees to lock it. Thats the only wat i know of. You can get new cable kits from aw direct towing. I have a brand new adapter kit (if yours hooks up different) that i did not need.If you would want to go that route let me know.
Johnny Blacks Butcher Shop
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | yes the "T" knob is the 'throttle' and hooks to the carb thru the cable which should be pretty obvious when you look under the dash and follow yer eyes thru the firewall to the carb
the throttle was intended as a way to up the idle for running PTO things, as on Johnny's tow truck, or for the warm up you do, or to hold a very slow granny-low crawl in the farm field pickin up the hay bales - VERY unsafe thing to use as a cruise control considering there's no automatic release in an emergency
Bill | | | | | Joined: Mar 2002 Posts: 990 Member | | Member Joined: Mar 2002 Posts: 990 | Your wire probably just broke, or the little slider might have just come loose. | | | | | Joined: Jul 2005 Posts: 2,031 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 2,031 | If I remember it has an outer housing like old lawn mowers. I covered mine w/ heat shrink tubing and am able to use a motocycle cable greaser to 'lube' the hard wire 'T'. the luber looks like http://www.motorcycle-parts-and-acc...able-lubricator-black-gold-prod3257.html about $10. @ any good m/c shop in town.
Jim & Caroline The highway is for gamblers, better use your good sense." Gooday-that's my 1¢ answer due to the lousy economy ~ cause I ain't got - no . mo . doe Every Shaver | Now Can Snore | Six More Minutes | Than Before ... | Half A Pound for Half a Dollar | Spread On Thin | Above the Collar || BURMA-SHAVE
| | | | | Joined: Jan 2005 Posts: 1,682 Extreme Gabster | | Extreme Gabster Joined: Jan 2005 Posts: 1,682 | Both my '46 trucks have the factory 'T' knob.. only used it a few times on real cold days when I wanted to run higher than normal idle RPM's to warm up the engine.
As Red points out, it would be useful in the larger trucks with PTO's for running the pump.
A '66 is 20 years into the future, so technology could have changed things.. but in '46 the 'T' knob is connected to a cable the same size as you'd find on your typical lawn mower throttle cable, and connects to the throttle on the carb.
I can't imagine it would be a real accurate, reliable, or safe cruse control, tho.
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | sctually Jim, if the throttle cable is lubed it'll wind up not working eventually - needs the friction resistance to stay in one position against the throttle return spring and vibration - someone here awhile back had just that problem
Bill | | | | | Joined: Oct 2005 Posts: 738 Shop Shark | | Shop Shark Joined: Oct 2005 Posts: 738 | cool beans, thanks for the replies. i do not use it for cruise control...it is tempting at times though. anyway thanks for the info.
"Never tell people how to do things. Tell them what to do and they will surprise you with their ingenuity." - George S. Patton My Machine | | | | | Joined: Apr 2002 Posts: 1,571 Shop Shark | | Shop Shark Joined: Apr 2002 Posts: 1,571 | A real throttle cable will have a "flat" machined on the inside of the tube and on the metal section of the cable where the knob attaches. You can turn the knob slightly to "lock" it in place. The repop junk is round all the way around. | | | | | Joined: Jun 2000 Posts: 2,773 'Bolter | | 'Bolter Joined: Jun 2000 Posts: 2,773 | Originally posted by Fort Knox: cool beans, thanks for the replies. i do not use it for cruise control...it is tempting at times though. anyway thanks for the info. There you go trying to be different. When I was driving semis for a living (the 70s) we used the throttle as cruise control. I was even known to put my foot on the dash to stretch out. But I only did that on lonely stretches of highway, like in western Oklahoma.
Fred 52 3600 69 C-10
| | | | | Joined: Jul 2005 Posts: 2,031 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 2,031 | Hey Bill I know what you mean and agree w/ you. When I used to use mine the lube helped get the thing moving. In other words it was rusted or stuck and that helped. I also think the friction that would still be there is enough to make it work as a very primitive throttle cruise control, but it would slowly drop in speed.
| | | | | Joined: Sep 2005 Posts: 254 Shop Shark | | Shop Shark Joined: Sep 2005 Posts: 254 | its just like a choke cable only instead of running the choke butterfly it runs the throttle butterfly with all the ones i've seen theres no twist to it just pull it out like a choke Nate | | | | | Joined: Oct 2005 Posts: 738 Shop Shark | | Shop Shark Joined: Oct 2005 Posts: 738 | Yeah there is no twist to mine. It is just a stright pull out like the choke. Fred, I like your style, I knew I wasn't the only one who had done this. There are not a lot of flat spots where I live, it is known as the "Rolling Hills" so I am kind of SOL there, but if I were a Kansas resident I bet it could be used a lot. Thanks for the posts everybody.
Kyle
"Never tell people how to do things. Tell them what to do and they will surprise you with their ingenuity." - George S. Patton My Machine | | | | | Joined: Nov 2005 Posts: 146 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 146 |  cruise control? hahahahahaha. now thats funny.  | | | | | Joined: Jun 2002 Posts: 179 Shop Shark | | Shop Shark Joined: Jun 2002 Posts: 179 | demo man...if you think that is funny, ask what factory air conditioning is in a new topic!
When I go cruisin' in the old truck....women smile, men weep and dogs beg for rides.
| | | | | Joined: Nov 2005 Posts: 146 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 146 | hahahaha. well i just roll down the windows for my ac. and the 2000 dodge i have never gets the ac used...  just the way that question was worded had me rolling with all kinds of visuals. like jed clampits old truck from the beverly hillbillys  | | | | | Joined: Dec 2005 Posts: 324 Member | | Member Joined: Dec 2005 Posts: 324 | i just looked at my 39. the cable end at the carb is like the choke cable. but slides through a swivel on the throtle. it can move free through this swivel, and has a stop to pull the carb opened. i remember driving across the plains in a 59 using the T nob as "cruse control" very dangerous.
"It ain't a truck if you can't hose out the cab."
| | | | | Joined: Dec 2003 Posts: 1,144 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 1,144 | Fred T and Ft knox used to do the same thing late at night in the midwest pull throttle latch and cruise. Just replaced the throttle cable on my 38 gonna have to look at the old one (if I can find it) to see if it had a flat side to lock in. | | | | | Joined: Mar 2006 Posts: 23 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2006 Posts: 23 | I had some old timers tell me(years ago)about puttin a "clothes pin on the throttle" cable, to keep it from vibrating closed and cruisin thru Kansas/Oklahoma or anywhere it was open road...Then theres always that Jim Croche song, with that line, "He's got a broomstick on the throttle"...
KEEP ON TRUCKIN,MAMA... TRUCKIN TILL THE BREAK OF DAY... I SAID,KEEP ON TRUCKIN,MAMA... TRUCKIN MY BLUES AWAY...
| | | | | Joined: Nov 2005 Posts: 146 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 146 | hey cosmic. what part of so or are ya? im in grants pass off and on. | | | | | Joined: Mar 2006 Posts: 23 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2006 Posts: 23 | well well well...how bout...CAVE JUNCTION.
