0 members (),
91
Mod | | | Forums66 Topics128,024 Posts1,055,393 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#20177 04/15/2003 6:07 PM | Joined: Feb 2003 Posts: 66 Shop Shark | | Shop Shark Joined: Feb 2003 Posts: 66 | because fo vapor lock (on 80 degree days) I was wondering it I could re-route my fuel line to get away from this problem. Possibly run a rubber line over the top of the engine and straight down.
I tried insuating it, but it didn't change anything. Could it possibly be my fuel pump gets that hot?
Thanks Brian K
49 chevy 235 engine
Sometimes, David beats Goliath. Nobody talks, however, about how many little guys Goliath already beat into the ground. . .
#20178 04/15/2003 7:20 PM | Joined: Jan 2003 Posts: 687 Shop Shark | | Shop Shark Joined: Jan 2003 Posts: 687 | BrianK: I don't think I would want to run a rubber hose over top of motor (Retired firefighter) anyway are you sure you are vapor locking. Another trick is to feed your steel line thru a rubber hose still looks nice and then reflare your ends. Try the aluminium foil wraped around the fuel pump first might be a way to isolate the problem. Ya never know. popcorn The Truth is Out There (we'll find it) | | |
#20179 04/16/2003 10:13 AM | Joined: Feb 2001 Posts: 1,897 Member | | Member Joined: Feb 2001 Posts: 1,897 | Five or six wooden clothes-pins on the fuel line will act as a heat-sink and may work as a temporary fix to see if the problem goes away. If it does, you can work ideas from there.
#20180 04/16/2003 11:49 AM | Joined: Jan 2001 Posts: 662 Shop Shark | | Shop Shark Joined: Jan 2001 Posts: 662 | Vapor lock typically is a suction side problem - between the pump and the tank. Check there for fuel line/exhaust proximity. As long as liquid gets to the pump, it'll push, but if it's sucking vapor you're stopped. | | |
#20181 04/16/2003 3:36 PM | Joined: Jun 2000 Posts: 2,773 'Bolter | | 'Bolter Joined: Jun 2000 Posts: 2,773 | True vapor lock is rare in these trucks with a six. The fuel line from the tank to the pump should be nowhere near the exhaust if your tank is original configuration.
Fred 52 3600 69 C-10
#20182 04/16/2003 3:38 PM | Joined: Feb 2003 Posts: 66 Shop Shark | | Shop Shark Joined: Feb 2003 Posts: 66 | I put some line insulation on the fuel line the other day (not sure what you call it, rubber on the outside, fiber material on the inside) and it had no big affect.
The exahuast comes off the other side of the engine, so that cant be a problem.
----What it does ------
After idling for a few (2 or 3) min. the engine still runs fine, but as soon as you put it into gear and let out of the clutch, it has a verry, verry, shortage of power, and almost dies. Once you push the clutch out, then it runs and raps up fine.
If I pull out the choke about 3/4 of the way, I can make it run good enough to get home (1.5 miles Max)
Thanks for your help
Brian K
#20183 04/16/2003 4:30 PM | Joined: Dec 2001 Posts: 1,745 Member | | Member Joined: Dec 2001 Posts: 1,745 | I think you need a carburator rebuild. Also check your vacuum advance.
54 3100 with 235 62 flatbed dump C60 with 261
#20184 04/17/2003 12:13 AM | Joined: Feb 2003 Posts: 66 Shop Shark | | Shop Shark Joined: Feb 2003 Posts: 66 | I rebuilt carb. about 2 years ago (400 miles) and my vacume advance works, even if it doesn't work well, and it runs fine until it gets warmed up, and even then. Until I leave it sit still for a little while.
Could it still be the vacume advance?????
Thanks Brian K
#20185 04/17/2003 1:02 AM | Joined: Dec 2002 Posts: 571 Shop Shark | | Shop Shark Joined: Dec 2002 Posts: 571 | Your heat riser may be frozen. Also try a carb spacer which insulates the carb from the hot manifold. | | |
#20186 04/17/2003 1:43 AM | Joined: Dec 2001 Posts: 1,745 Member | | Member Joined: Dec 2001 Posts: 1,745 | That is not many miles for two years. Sitting still the carburator actually needs more maintenance than if you were using it daily.
#20187 04/22/2003 3:33 PM | Joined: Feb 2003 Posts: 66 Shop Shark | | Shop Shark Joined: Feb 2003 Posts: 66 | tony, 300 miles of that were within the last month  . Next time it does it, I will check the heat riser, and then, if it is OK, I will check the Carb. Thanks for all your guy's help Brian K
#20188 04/23/2003 7:58 PM | Joined: Jan 2001 Posts: 230 Shop Shark | | Shop Shark Joined: Jan 2001 Posts: 230 | Get rid of that rubber hose , it'll make the fuel hotter by retaining heat . (guess how I know)
Also check the fuel pump output pressure - I had one that would vapor lock but always passed the visual volume test - turned out it was dying and only put out 2 PSI maximum ! no wonder it would vapor lock on hot days . a kit or new one (cheap) will fix that .
Last thing , disconnect the line to the inlet of the pump , a _goodly_ stream of gas should come roaring out , not just a thin stream or dribble - lots of times crud in the fuel tank will block the shutoff valve in the bottom of the tank - these old nails don't have socks/screens on the pickup point in the tank .
Wooden clothes pins will get you going when it vapor locks in traffic but not on rubber hose !.
-Nate There is no problem so difficult it cannot be overcome by generous application of brute force & ignorance
