3 members (MickeyP, Joe H, Jon G),
121
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,050 Posts1,055,646 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#20144 12/15/2001 9:27 PM | Joined: Sep 2001 Posts: 30 Member | | Member Joined: Sep 2001 Posts: 30 | No matter what i try i cant get my engine all the way in the tranny.The pilot alignment tool slides in efotlessly.My question is since im only puting the engine back in till i can get it overhaulled this spring is it safe to be standing on the front motor mount bolts or do i risk breaking them off.Thanks for your help...Ron
1942 1/2ton 1951 1/2 ton 1960 biscayne sedan 1968 ihc scout 1972 #### 3/4 ton
#20145 12/15/2001 9:38 PM | Joined: Jun 2001 Posts: 379 Shop Shark | | Shop Shark Joined: Jun 2001 Posts: 379 | | | |
#20146 12/15/2001 9:39 PM | | Anonymous Unregistered | | Anonymous Unregistered | Ron, Did you by chance put grease in the pilot bearing cavity? This could be acting as a hydraulic stop if your bearing is tight. Just a thought . . . I wouldn't try to support the motor only on the front motor mount - it'll break. Get a couple of big hammers and crow bars, smash your thumb with a hammer and then go at it again, it will go in and this is good training for becoming a curmudgeon.  | | |
#20147 12/15/2001 9:46 PM | Joined: Sep 2001 Posts: 30 Member | | Member Joined: Sep 2001 Posts: 30 | No i didnt add any grease.As for the hammers i thought of that but where is it safe to pound?
#20148 12/15/2001 10:07 PM | Joined: Feb 2001 Posts: 1,096 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 1,096 | Ron , have you had the nose off the front of the g/box ?? It is easy to replace the washers with ones too big on dia. that will hold the g/box back . The nose (that the thrust brg slides on) is a close fit in the bell housing , It must be attached with the correct screws and washers . | | |
#20149 12/15/2001 10:57 PM | Joined: Sep 2001 Posts: 30 Member | | Member Joined: Sep 2001 Posts: 30 | Dusty,nothing was touched ob the tranny or bell housing.I even tred turning the engine over by hand in gear. rolled it abought 10 inches.
#20150 12/16/2001 1:35 AM | Joined: Dec 2001 Posts: 1,248 'Bolter | | 'Bolter Joined: Dec 2001 Posts: 1,248 | Slow Rider; Do the number of splines on transmission shaft match the number of splines in clutch disc? Could parts man have givin' you the wrong disc? Just a thought.  | | |
#20151 12/16/2001 3:03 AM | Joined: Sep 2001 Posts: 30 Member | | Member Joined: Sep 2001 Posts: 30 | Everything im dealing with is original 1942.I removed the engine to blast and paint the frame. i need to get the engine in the frame for storage only till i can get it overhauled in the spring The only thing i havent put back in is the throw out bearing .would this cause my problem?
#20152 12/16/2001 3:37 AM | Joined: Dec 2001 Posts: 1,248 'Bolter | | 'Bolter Joined: Dec 2001 Posts: 1,248 | Ron, Throwout bearing shouldn't keep it from going together. Try taking two bolts that will screw into bellhousing and cut the heads off to help align transmission to bellhousing.  | | |
#20153 12/16/2001 3:57 AM | Joined: Nov 2001 Posts: 16 Member | | Member Joined: Nov 2001 Posts: 16 | Is it possible that the clutch disc is in backwards? That is a problem many of us have been troubled with. Just an old memory. Chb46 | | |
#20154 12/16/2001 4:04 AM | Joined: Jan 2001 Posts: 47 Member | | Member Joined: Jan 2001 Posts: 47 | Ron
Is the crankshaft and trans input shaft in a strait line? Have you tried putting the trans in gear so it turns a little as you rock truck back and forth by pushing motor against trans?
Judd | | |
#20155 12/16/2001 5:20 AM | Joined: Sep 2001 Posts: 30 Member | | Member Joined: Sep 2001 Posts: 30 | This afternon i removed the motor again and easaly put a piolot alignment tool in and out. I thought that the engine and trany were a little out of alinment and moved the frame to straighten it out.Ieven tryed moveing the the cumalong forward and back on the chain hooked on the engine t o try different angels.I also tryed raising and lowering the tranny.Irolled the frame back and forth abought 10 inches by turning the motor over in gear and moveing the engine side toside wile pushing back with a pry bar.Im now going to try some jack daniels.Ive got to get the truck back in the garage before it snows again.My thoughts are to cut a couple of blocks of wood narower than the front mounting bolts but taller to take the pressure of the bolts. any and all input is greatly apreciated . Thanks...Ron
#20156 12/16/2001 6:14 AM | Joined: Jan 2001 Posts: 198 Member | | Member Joined: Jan 2001 Posts: 198 | why not just leave all the clutch / pressure plate & flywheel out till the spring, and just bolt the tranni to the motor. :rolleyes: | | |
#20157 12/16/2001 6:43 AM | Joined: Sep 2001 Posts: 30 Member | | Member Joined: Sep 2001 Posts: 30 | Albert, ididnt fell confortable wrenching on it to re move the cluth and stuff with it suspended from the ceiling.Now for the good news.IFINALLY GOT THE DARNED THING IN.What a pain in the but.Iwas raising it to put some wood under to block it up so i could get it back in my shop and thought id try one more time tonight.This time i had a helper.while i turned the engine over in gear and moved the engine side to side i had my son on the prybar pushing on the engine.It finally went.Thank you to every one for all the great sugjestions.I hope i can count on your help in the future...Ron
#20158 12/16/2001 6:56 AM | Joined: Aug 2000 Posts: 523 Member | | Member Joined: Aug 2000 Posts: 523 | Congrats Ron....Doesn't it feel good to work hard and win sometimes!! | | |
#20159 12/16/2001 7:08 AM | Joined: Sep 2001 Posts: 30 Member | | Member Joined: Sep 2001 Posts: 30 | darn STRAIGHT...It takes alittle presure off and i can once again look forward to going out to my shop again.It puts off that crumegedon feeling too. [img] http://wsphotofews.excite.com/005/ja/1a/Np/dU69292.jpg[/img] Youre all welcome to a cold one on me.
#20160 12/16/2001 7:53 AM | Joined: Feb 2000 Posts: 587 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 587 | Slow...you have a Juke box and a pool table in your shop?? OR, do you just have your truck parked in your basement that has a garage door on it?  :p
G.L. Grumpy's Old Iron Ranch Huntington, IN 46750
MM R tractor, Speedex and Power King tractors
#20161 12/16/2001 10:59 AM | Joined: Apr 2000 Posts: 81 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2000 Posts: 81 | Wow,I've seen taverns with less cool stuff in them. When do you find time to "work" :p? As for your problem, I once had a similiar experience. In my case, the pilot bushing had been mushroomed ever so slightly by the input shaft on the tranny during my first attempt at putting things together. Each effort after that just compounded the problem.
If at first you don't succeed, get a bigger hammer.
1941 Pontiac business coupe 1947 Chev Coupe 1969 GTO ragtop
#20162 12/16/2001 2:38 PM | Joined: Sep 2001 Posts: 30 Member | | Member Joined: Sep 2001 Posts: 30 | My shop is a freestanding building abought 30 yards from the house.Its my home away from home. Next to the juke is a portable bar wicth helps when problems arise. [img] http://wsphotofews.excite.com/020/XQ/Kc/oq/dS67184.jpg[/img] [ 12-16-2001: Message edited by: Slow Rider...Ron Raatz ] my progress pics [ 12-16-2001: Message edited by: Slow Rider...Ron Raatz ]
#20163 12/21/2001 6:21 PM | Joined: Aug 2001 Posts: 258 'Bolter | | 'Bolter Joined: Aug 2001 Posts: 258 | Slowrider, Trying to line an engine up with a tranny shaft is just plain torture! ('least it always is for me!) Suggestion for your post-rebuild installation: remove the tranny from the chassis first. If your truck has a 3-speed, that's a light little gearbox and is a heck of a lot easier to fidget into place than a couple hunnerd pounds of stovebolt swingin' from the ceiling!  Engine in chassis first, then install the tranny. 'Nother tip: get yourself a couple of long bolts the same size as the tranny to bell housing bolts, and cut their heads off and put "screw-slots" in them to make: Guide Studs! Use them in place of the upper tranny bolts when re-installing the tranny, and it will help support the weight of the trans, leaving your hands free to "adjust" the angle of attack, as well as rock the u-joint yoke back and forth to line them splines up at the clutch plate! Once you get the tranny seated and the lower bolts installed, then remove the guides and install the uppers. (This trick also works when you've got a heavy 4-speed on a floor-jack! Good for cylinder heads too!) Nice shop! I can't even move around in mine; and that's before all the junk ( I mean "treasure") went in! Frank
Frank McMullen 1941 Chevy dump truck 1949 GMC 100 pick-up 1954 Chevy 3600 pick-up 1955.1 4400 dump truck 1941 De Soto & other MoPars 1928 Model A F**D Special Coupe
#20164 12/22/2001 2:13 AM | Joined: Sep 2001 Posts: 30 Member | | Member Joined: Sep 2001 Posts: 30 | Frank,thanks for the great tips.Its nice to have a forum like this where people share there tips and experience.With the collective help of others and a little luck, i may even get my truck put back together. Thanks again to all...Ron
#20165 12/22/2001 5:55 AM | Joined: Jan 1970 Posts: 365 Shop Shark | | Shop Shark Joined: Jan 1970 Posts: 365 | Try reassembling a 10,000 lb tractor, with a 3000 lb engine on a splitting stand. Everything has to be lined up PERFECTLY in order for things to slide together correctly. Do not force things together, at most use MODERATE come-a-long pressure at the most. It should go all the way together before you put in a bolt to hold things together.
I have the best luck installing truck transmissions leaving the tranny in gear. You can apply light come-a-long pressure and turn the output shaft, which will turn the imput shaft and allow the splines to engage the clutch disk. Also, if you are installing a new pilot bearing, make sure it fits on the input shaft. Don't just look at it, try it on the shaft. Also, try the clutch disk on the input shaft. If nothing else, this is a mind game to play on yourself to prove that the tranny HAS to go on since the only things that could impede progress did indeed fit at one time. | | |
#20166 12/22/2001 6:49 AM | Joined: May 2001 Posts: 477 Shop Shark | | Shop Shark Joined: May 2001 Posts: 477 | uh, does this mean you guys are gonna rag me alittle for the satellite dish on the hillbilly garage?  | | |
#20167 12/22/2001 1:47 PM | Joined: Sep 2001 Posts: 30 Member | | Member Joined: Sep 2001 Posts: 30 | On the subject of transmissons.Ive got a new clutch,pressure plate and throwout bearing. Is it recomended to replace the cluth fork?[Not sure if thats the right name,holds throwout bearing]Do these wearout?I intend to put a lot of miles on this truck when its done and want to do things the right way the first time.Other than adding hardened valves and seats when i have the engine gone over are there any other modifications recomended for the 216?As for the hill billy sattelite,ive got a tv out there but dont turn it on alot as my ocasional helpers[wife and kids] get to distracted. As always,thanks for your expertice...Ron
#20168 01/02/2002 8:02 PM | Joined: Aug 2001 Posts: 258 'Bolter | | 'Bolter Joined: Aug 2001 Posts: 258 | Racecarl,
You brought back memories from 25 years ago, helping Dad "split" the **** 9-N to put a new ring gear on the flywheel!
We're darn lucky no one got hurt!
The worst "line-up" situation I personally dealt with was in Mom's VW campmobile; (don't miss working on that beast :mad: )
#20169 01/02/2002 8:42 PM | Joined: Apr 2000 Posts: 499 'Bolter | | 'Bolter Joined: Apr 2000 Posts: 499 | I would just like to ask if you charge for parking while you give haircuts. I have a TV and a cabinet full of magazines, but no barber chair.
'67 GMC 3/4 292 4spd
#20170 01/02/2002 10:29 PM | | Anonymous Unregistered | | Anonymous Unregistered | Frank remember very well splitin the father inlaws 9N to change the ring gear. Tossed the flywheel outside in the snow and warmed up the ring gear a little with the torch poped it on with a wood block and hammer.Man this is a great site get to remember all that stuff we did many years ago.What was the name of those old english fords(big ones)the farmers had back in the late 60's ealy 70's remember waiting 3 weeks for a clutch with that thing restin on a couple blocks of wood.Studs work good to reinstall trans. Ron that is one cool shop you got there.You dont normally have to change the throw out fork unless its badly worn or damaged.
[ 01-02-2002: Message edited by: Phat ] | | |
#20171 01/04/2002 4:49 AM | Joined: Sep 2001 Posts: 30 Member | | Member Joined: Sep 2001 Posts: 30 | Richard, if you let me give that haircut ill not only let you park for free ill throw a couple dimes in the jukebox for you.Id have to make up for the bad haircut some how... Phat,thanks for the coments and the fork info. Ron
#20172 01/23/2002 9:48 PM | Joined: Dec 2000 Posts: 14 Member | | Member Joined: Dec 2000 Posts: 14 | Slow Rider, had my 216 proffesionally rebuilt last summer. Removed and re-installed as a unit so I had the tranny out. I replaced the clutch, pressure plat and TO bearing. Had the same problem you mention. Carefully granked the bolts down in rotation. It went, but slow. Following the installation, it occured to me that although the pilot tool lined up right, I think the problem was the clutch was slightly out of line. If I have to do it again, I'll start the bolts and put a pipe on the clutch lever and release the plate a couple of times during the process. The pilot tool is just not that exact and I think may allow just a wee bit of mis-alignment, enought to creat the problem you described and I experienced. Good luck. | | |
#20173 01/23/2002 10:09 PM | Joined: Feb 2001 Posts: 1,094 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 1,094 | I have pinball machine, juke box and fridge in the garage. Needless to say not a whole lot gets done, especially if I have help.
Tommy 59 apache 1/2t 261 short stepside | | |
#20174 01/24/2002 3:31 AM | Joined: Sep 2000 Posts: 390 Shop Shark | | Shop Shark Joined: Sep 2000 Posts: 390 | Pinball machine hmm... i knew there was some thing missing.Accualy ive been lookin for one for a while, i just havent found one in my price range. CHEAP!Most of my treasures were cheapo auction finds.I got the 1960 juke box and the barbers chair for 10 bucks.I did how ever put a couple hundred in the juke haveing the amp and selector rebuilt.The pop machines were 2 for 15 bucks.Only needed 1 so i gave the other to a buddy.Our house isint all that big so when we have get togethers the shop is where we head.We rcently celebrated newyears out there with our anual new years eve pool and darts tournamet.At easter ive got 6 familys out there haveing fun.[img] http://www.imagestation.com/picture/sraid28/pd06787b93622c7347ace03de56ce1695/fdfced64.jpg[/img] [ 01-23-2002: Message edited by: slowrider ]
1942 1\2 Ton 1951 1\2 Ton 55 willys cj-5 1954 and 59 Cushman Scooter 1960 Biscayne Sedan 1965 G/10 panel van 1966 C/30 Grizzly Motorhome You know you're a 'Bolter when your daily driver is older than you are... My progress pics | | |
