5 members (Otto Skorzeny, Steelonsteel, Bill Hanlon, dt235sd, Wayne67vert), 124 guests, and 5 robots.
Topics128,034
Posts1,055,536
Members48,425
#201383 02/17/2006 10:15 PM
Did anybody tried to put a Blazer rearend on a 1942 chevy truck ?
1) Will the wheels (lugs) fit ? Original wheels
2) I know it's wider put would it be to wide ?
Cheers
Greetings from Belgium.
Don't waste water, drink wine !
1946 Chevrolet 1/2-Ton Truck
#201384 02/17/2006 11:09 PM
search the archives on "blazer rear" and you will find more information than you care to read including the fact that it has 6 lugs and a close enough width to stock to work
#201385 02/19/2006 4:28 PM
Most S10 trucks had the 5-on-4-3/4 inch bolt pattern. I'm not positive what your truck has. If using the S10 rear, use a 4x4 rear as they are approx 4 inches wider than the 2wd. The 2wd S10 rear is a little narrow for our trucks without some significant outward offset to the rims. Don't ask me how I know <smile> Best wishes from the other side on the pond. - MV
46 Chev One Ton Panel - S10 Frame Project
"What if the Hokey-Pokey is REALLY what it's all about?" - J. Buffet
#201386 02/19/2006 5:01 PM
One other thing. Blazers had metric thread on the lug nuts. mv
#201387 02/19/2006 6:15 PM
I thought we were talking about K5 blazers with a 6 lug rear.
#201388 02/19/2006 6:22 PM
Pipercub,
Also take a look at the new trailblazer rear...I read somewhere the width was right..
I realize you probably don't have piles of them laying around in junkyards in Belgium...but..if you are having one shipped from the states..it might be worth a look
Since the trailblazers have been out for awhile, they are starting to show up in the junkyards after people drive them sideways down the freeway at 75 MPH on icy roads...most are light rolls and don't mess up the drivetrain too bad.
