4 members (55shaker, Gdads51, 1955 1 Series, 1 invisible), 122 guests, and 3 robots.
Topics128,070
Posts1,055,900
Members48,429
#201344 02/17/2006 8:44 AM
i recently bought a 54 chev and was told that it has a newer motor than the org 54 235. these numbers are stamped on the bloc 383 6548 gm25. does these numbers tell you what year the motor is? or is there some where you can look up these numbers thanks all ted
#201345 02/17/2006 2:43 PM
Hey Teddyjames, looks like the number you have is from the head except the 5 in your number is actually an 8. That head was used on 58 to 62 235s.
If you look at the passenger side of the block,right at the distibuter you will find a similar string of numbers and yes from those numbers you will be able to get an idea of the year you have.
Also there is numbers on the distributer pad that will decifer the date built and plant of origin for your motor.
You can visit www.inliners.org site for all the listings.
Hobert
"The Lord is my shepherd"
#201346 02/17/2006 9:48 PM
Quote
According to that then I have a 55-57 261 in my 58 is that correct? 3837012<~block numbers from distributer plate.
#201347 02/18/2006 12:37 AM
thanks all of you wizzards i will check those numbers out and see what i have. could not to it without you. my hats off to all of you ted
#201348 02/18/2006 2:20 AM
update on searching for numbers on 235 the number 3836548 was indeed suppose to read 383 6848 and looking on the inliners web page info that number is for a 1956 head. thanks for that tip and decent 35 says numbers over starter. mine says F 10 1 so maybe june 10th 1961? thanks again ted
#201349 02/18/2006 4:00 AM
Quote
Originally posted by 58Apache_Outlaw:
Quote
Hey 58 apache,according to inliners for block casting number 3837012 it is listed as 216 engine for Chevrolet 1942 to 1951.
It is also listed as 55-57 261 just as you say.
Go back to inliners and make a second check and look for 42-51 216. I have been checking casting numbers on inliners and that is the first time I can recall where the same casting number is given for two different engines.
Theoreticly you can check the date code on the distributor pad and decifer the year.
Hobert
