3 members (Hotrod Lincoln, BC59, 1 invisible),
134
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,047 Posts1,055,538 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2002 Posts: 117 Shop Shark | | Shop Shark Joined: Aug 2002 Posts: 117 | Hello all: i have a question,,yesterday.i couldn't get my 50 started,,(Snow had to be Plowed)  so i left key off,,put truck in reverse,let clutch out,,and stepped on starter switch...truck slowly went back..question is..Is this Dangerous??,,or did i already wreck something,,I hope Not..We have Ice around Here,In Spots..and I couldn't push or pull truck with another vehicle,So i thought I'd try what i did..Did I "Hurt" anything??.. | | | | | Joined: Oct 2005 Posts: 4,249 "Hey! I sound like Darth Vader!! | | "Hey! I sound like Darth Vader!! Joined: Oct 2005 Posts: 4,249 | Probably not. However, continued actions like this will drastically shorten the life of the starter. | | | | | Joined: Mar 2005 Posts: 284 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 284 | The starter in the truck or the person behind the wheel | | | | | Joined: Sep 2005 Posts: 310 Shop Shark | | Shop Shark Joined: Sep 2005 Posts: 310 | If he has to replace the starters, I'm not sure, but a cold damp floor will get to you in time.  | | | | | Joined: Oct 2005 Posts: 275 Shop Shark | | Shop Shark Joined: Oct 2005 Posts: 275 | Your not the only one who's ever done that.
38 original 48 panel 59 stepside 46 in the back forty
| | | | | Joined: Feb 2005 Posts: 199 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2005 Posts: 199 | I dont think you hurt anything by doing this or wrecked anything.The battery will suffer the most damage when you use the starter to move the truck. This is an age old practise and all you are doing is using the starter motor as a winch,which was not designed for the load you put on it. I would not suggest you do this very often and certainly not for extended lengths of time,a few seconds intervals will allow the starter windings to cool.Dont drain your battery because that will destroy it.
Hobert
"The Lord is my shepherd"
| | | | | Joined: Jul 2005 Posts: 1,158 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 1,158 | Don't do it too often. If you do, you'll wreck your starter.
I doubt that you've hurt anything, though.
I've done it with tractors before. | | | | | Joined: Oct 2005 Posts: 4,249 "Hey! I sound like Darth Vader!! | | "Hey! I sound like Darth Vader!! Joined: Oct 2005 Posts: 4,249 | Hah!! Reminds me of my little brothers Honda Civic years ago. He had lost the clutch cable on it and needed to get it home. It was maybe 5 miles from there. So the task left to me ( the mechanic / fixit guy of the family ), I put it in first and started it at any red light. After that it was just a matter of gently letting the synchros do their job. That and trying to time all the street lights. Ah! The fun stuff I used to do! | | | | | Joined: Feb 2006 Posts: 6 Junior Member | | Junior Member Joined: Feb 2006 Posts: 6 | nope. shouldn't be a problem. that's common practice in the 4x4 world. after stalling out, especially on an incline, the last thing you want to do is depress the clutch pedal and start rolling backwards/forwards while attempting to start the vehicle. better off "starting" it in gear. i've done it dozens of times in my jeep - on the same starter/battery. the caveat is that i don't do it often, and i don't over-use the method on any one outing. wally
right
| | | | | Joined: Aug 2002 Posts: 117 Shop Shark | | Shop Shark Joined: Aug 2002 Posts: 117 | | | | | | Joined: Mar 2005 Posts: 1,636 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 1,636 | My 58 died at an intersection one time, refused to start. Ambulance coming in the background, used the starter to get out of the way. People sure looked at me funny, but it moved and I didn't have to push. | | | | | Joined: Jan 2005 Posts: 1,682 Extreme Gabster | | Extreme Gabster Joined: Jan 2005 Posts: 1,682 | I agree with the folks here.. not a method you wanna use to drive the vehicle across town or anything, but if you need to move it and it won't start, it works in a pinch.
I've used this method to run a car up on a trailer on at least two occasions.
| | | | | Joined: Oct 2005 Posts: 738 Shop Shark | | Shop Shark Joined: Oct 2005 Posts: 738 | ran out of gas one time within sight of the station. i "starter winched" myself about three block and pulled in. people looked at me like i was retarded but it wokred and i did not have to push the thing to the gas station. i would rather take the ego hit than push my bolt down the road, that thing is heavy!
"Never tell people how to do things. Tell them what to do and they will surprise you with their ingenuity." - George S. Patton My Machine | | | | | Joined: Sep 2003 Posts: 2,384 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 2,384 | back when I was wrenching full time, I 'cranked' many a manual shift that wouldn't run into the shop, I even carried a wire to bypass clutch switches. brian | | |
