| | | Forums66 Topics128,026 Posts1,055,409 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2006 Posts: 5 Junior Member | | Junior Member Joined: Jan 2006 Posts: 5 | I'm putting a 350 v8 in a 1965 sb step side that was previously a 6 Cyl. The engine went in, but the firewall clearance is is real tight especially with the tall valve covers. Have any of you ran into this problem and what can be done to fix it. Thanks for any input | | | | | Joined: Nov 2004 Posts: 1,552 Shop Shark | | Shop Shark Joined: Nov 2004 Posts: 1,552 | rustynail:
The clearance of the valve covers, distributor and air cleaner is rather minimal with a V8 application. Converting to an HEI also makes the distributor rather close, but it will clear. Perhaps a set of short small block V8 valve covers in place of your tall ones will eliminate your clearance issues at the firewall. This will avoid shifting the motor mount location forward, which can be done, but is rather involved. Good luck with your '65 C10 project. | | | | | Joined: Jan 2006 Posts: 5 Junior Member | | Junior Member Joined: Jan 2006 Posts: 5 | Thanks for the reply. I can't chang the valve covers due to using roller rocker arms. Are the original V8 trucks this close to the firewall? Could I move the engine mounts and the crossmember forward about an inch without lenghting the driveline? | | | | | Joined: Sep 2003 Posts: 343 Member | | Member Joined: Sep 2003 Posts: 343 | Some vendors sell new firewall sheet metal to address this issue.
Jim
1954 GMC 1/2-ton Longbed 1971 Pontiac LeMans Sport
| | | | | Joined: Jan 2005 Posts: 24 Junior Member | | Junior Member Joined: Jan 2005 Posts: 24 | On my 64 Suburban, I just used 67-72 factory small block engine stands. They bolted straight in, no mods, and it moved the engine about 3 inches forward.
As a matter of fact, I used all the 67-72 stuff, brackets, pulleys, driveshaft, everything. No mods needed whatsoever.
Tender caretaker of antique tractors and old trucks.
