6 members (1955 1 Series, 50Chevy3100, RdsLessTaken, DadsFirstPickup, tclederman, 1 invisible), 172 guests, and 3 robots.
Topics128,107
Posts1,056,225
Members48,436
#20050 01/18/2002 2:36 PM
I'm swapping a Sag 3 speed o/d onto my 26l. Would it be wise 9or necessary to add a transmission crossmember to support the tailhousing even though the tranny doesn't support the engine? Thanks.
#20051 01/18/2002 2:48 PM
Anonymous
Unregistered
Anonymous
Unregistered
You could if you wanted. But i have never seen the need as long as the driveshaft was balanced well and not some homebuilt hack job.
#20052 01/20/2002 12:38 AM
Hi, I did this swap a couple years ago into my '55 chevy 2 door sedan. I did not install a crossmember and, to date, no problems. I would not go to the trouble.
Chad
1955 Chevrolet 210 2 door Sedan
a 30,000 mile UNMOLESTED original, now my daily driver! Original 6 cylinder with a rebuilt '66-'69 Saginaw 3-speed Overdrive. Synchro low! Otherwise, everything original down to the spare tire. Interior is like new. Needs paint, but absolutely zero rust.
#20053 01/20/2002 1:50 AM
Thanks, Don.
