| | | Forums66 Topics128,052 Posts1,055,718 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#20044 02/27/2005 4:53 AM | Joined: Feb 2005 Posts: 2 Junior Member | | Junior Member Joined: Feb 2005 Posts: 2 | I just bought a 70 Chevy C10 Stepside to restore. It has an L6 - but how can I tell if it's a 250 or 292?
Thanks. | | |
#20046 02/27/2005 5:16 AM | Joined: Aug 2004 Posts: 51 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2004 Posts: 51 | The 292 has a by-pass hose from the stat housing to the water pump on the left side.
1965 C-10 Stepside
#20047 02/27/2005 5:18 AM | Joined: Feb 2005 Posts: 2 Junior Member | | Junior Member Joined: Feb 2005 Posts: 2 | Originally posted by TooMany2count: the 292 has a TALL side cover & the motor mounts are off set from one side to another.....joe Joe: Thanks! For my info, the 250's motor mounts are??? | | |
#20049 02/27/2005 6:12 PM | Joined: Feb 2000 Posts: 5,201 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,201 | The fuel pump on a 250 is under the distributor, and in the middle of the engine on a 292. 250 motor mounts are in the middle of the engine and 292s are middle left side, forward right side. A 292 is 1.75" taller than a 250. Side covers are also taller. Joe | | |
