1 members (Hotrod Lincoln),
57
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,094 Posts1,056,066 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2004 Posts: 17 Junior Member | | Junior Member Joined: Aug 2004 Posts: 17 | Hi..First time here and wondering if anyone can help me identify an engine in a 1952 parts truck I just dragged home. It has a casting # beside the distributor reading 9518105 It is bolted up to what appears to be the original 4 on the floor speed and has the enclosed driveshaft to rearend. Is there another place for an engine casting # I should be looking for? Thanks ....... Barry | | | | | Joined: Feb 2001 Posts: 1,897 Member | | Member Joined: Feb 2001 Posts: 1,897 | Stamped numbers on the flat pad next to the distributor and cast numbers oin the side of the engine block begins with CON4 or the like. engine decoder at www.jimcarter.com ohttp://www.americanclassic.com/paint_test.aspr Welcome to the StoveBolt
| | | | | Joined: Nov 2003 Posts: 117 Member | | Member Joined: Nov 2003 Posts: 117 | Mechainiac, better check that link.
Winona 1949 3100 5 Window Deluxe Cab
| | | | | Joined: Aug 2004 Posts: 17 Junior Member | | Junior Member Joined: Aug 2004 Posts: 17 | Thanks ......I'll due some scrap'in and try to find a number simular to CON4 and see what I come up with | | | | | Joined: Feb 2001 Posts: 1,897 Member | | Member Joined: Feb 2001 Posts: 1,897 |
