1 members (1 invisible), 46 guests, and 2 robots.
Topics128,043
Posts1,055,610
#20028 01/03/2004 1:23 PM
Okay guys I know this may be viewed as a dumb butt question, but how do you remove the draft tube from the engine. The only reference my manual makes to it is that it should be removed and cleaned. I getting ready to send block to shop for prep. I was under the imprssion that it just pushed into hole and the bracket bolt at the oil pan held in place (I have removed the bolt). I have soaked the crap out it with rust remover -- it stil doesn't budge. PLEASE HELP. Thanks
#20029 01/03/2004 2:03 PM
It normally is just sitting in place and secured by the bracket. The end is tapered so usually it is a snug fit. I used a rubber hammer to administer a little persuasion.
1951 1 Ton Completed
#20030 01/03/2004 2:09 PM
Thanks - suspicion confirmed -- now where did I leave my persuader ---
