1 members (Brian Moore),
95
Mod | | | Forums66 Topics128,030 Posts1,055,428 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#20028 01/03/2004 1:23 PM | Joined: Dec 2003 Posts: 103 Member | | Member Joined: Dec 2003 Posts: 103 | Okay guys I know this may be viewed as a dumb butt question, but how do you remove the draft tube from the engine. The only reference my manual makes to it is that it should be removed and cleaned. I getting ready to send block to shop for prep. I was under the imprssion that it just pushed into hole and the bracket bolt at the oil pan held in place (I have removed the bolt). I have soaked the crap out it with rust remover -- it stil doesn't budge. PLEASE HELP. Thanks | | |
#20029 01/03/2004 2:03 PM | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | It normally is just sitting in place and secured by the bracket. The end is tapered so usually it is a snug fit. I used a rubber hammer to administer a little persuasion. | | |
#20030 01/03/2004 2:09 PM | Joined: Dec 2003 Posts: 103 Member | | Member Joined: Dec 2003 Posts: 103 | Thanks - suspicion confirmed -- now where did I leave my persuader --- | | |
