4 members (5 Window 9434, ronsway, NJC, dt235sd), 152 guests, and 1 robot.
Topics128,108
Posts1,056,238
Members48,437
#200185 02/04/2006 6:54 PM
Well, the project continues. I am now in search of a replacement (steel) dimpled fender that matches the side mounted tire. None of the stock sources seems to have one.
Does anyone have any suggestions?
Baxter in Progress
www.jcl100.net
You mean besides a ball-peen hammer? lol
There was a thread awhile back on here where a fellow built a dimpled fender.. looked pretty good.
I dont know of anybody selling repro dimpled fenders.. but originals might pop up on eBay from time to time.
Yeah, I asked the guys at Filling Station about it, and they told me of somebody who HAD a dimpled fender and beat it out to make it smooth. I could call him. Geez! I could just see whacking it back in again...not.
I remember a tech tip somewhere of a guy that made a "dimpled" fender. He didn't beat the thing out though. He cut a portion out and inverted it and welded it back in. He may even have had a template that showed where to cut. If not on this site, you might try the GMC site.
It's still in the tech tips section.
1954 GMC De Luxe COE
Z
Z Offline
THINK of inserting an old front fender from a motorsickle into your fender could be a possible.
"After you skin yer knuckles, Mr Shifter ain't yer friend any more."
1942 Chevy 3/4 ton
Photo Site
1946 Chevy 5 window coupe/ute (new stray)
2000 Nissan Patrol 4x4 4.5l turbo diesel
Just look in the tech tips page, get the template, and turn around the piece you cut out. No need to drag other parts into the mix.
#200192 02/05/2006 11:29 PM
Put your fender in the swap meet to trade for a spare tire fender. I had 2 spare tire fenders and traded both for non spare tire fenders. One in the Stovebolt swap meet, one locally.
Ron Thompson
51 Chevy 1/2 ton
36 F@rd coupe
65 Riviera
Shmoo I suggest you send me a private message or a personal email.
Here's the link for dimple procedure...
http://www.stovebolt.com/techtips/sparetire/sparetire.htm
I've done it... it's not terribly difficult.
Andy
A man is like an old truck... He will rust out before he wears out...
#200195 02/07/2006 12:51 AM
mock up your tire about where you want it. follow the bolt's tech article. measure and mark the fender. after you cut that piece out, reverse it and weld it back in.
Jim & Caroline
Jerry Acheson
Indianapolis, IN
57 Chevy 3100
Every streetrodder in the world is looking for someone like you, they crave the smooth fender and you could probably draw boot money in a trade.
Evan
Can anyone read the placement dimensions for the template on the fender? I can get the 5 3/4 from the inside which would leave whatever on the outside of the fender. But how far up from the bottom? And, is there any tilt to the centerline as to its position on the fender? Or do you vertically plumb the mounting side of fender, the vertically align the centerline? :confused:
at the body shop i used to work at my boss took out the dimple on a 55 2nd - 59 bed had to drill out the spot welds and take the piece out and make up his own filler metal piece (couldn't just turn it around)
Nate
Link to my photobucket for pics of my vehicles
http://s238.photobucket.com/albums/ff17/OldIronChevy/
TF fenders are quite different from ADs.
Junior Member
Junior Member
i have a dimple fender that i want a smooth fender for off my 54, dont know if this is too old to matter anymore
I picked up a dimple fender about the same shape as the one on ebay for $20.00 at the Monroe swapmeet.I also had a friend that hammered his dimple in ,and after a little work it looked just as good as a stocker.
Lothar
