2 members (UtahYork, Southerntruck), 170 guests, and 5 robots.
Topics128,077
Posts1,056,013
Members48,433
#2001 08/10/2004 3:57 AM
Junior Member
Junior Member
Hi..First time here and wondering if anyone can help me identify an engine in a 1952 parts truck I just dragged home.
It has a casting # beside the distributor reading 9518105
It is bolted up to what appears to be the original 4 on the floor speed and has the enclosed driveshaft to rearend.
Is there another place for an engine casting # I should be looking for?
Thanks ....... Barry
53 1/2-ton GMC 4x4
54 Chevy 1/2-ton
#2002 08/10/2004 4:04 AM
Stamped numbers on the flat pad next to the distributor and cast numbers oin the side of the engine block begins with CON4 or the like.
engine decoder at www.jimcarter.com
ohttp://www.americanclassic.com/paint_test.aspr
Welcome to the StoveBolt cool
#2003 08/10/2004 4:13 AM
Mechainiac, better check that link.
Winona
1949 3100 5 Window Deluxe Cab
#2004 08/10/2004 4:15 AM
Winona
#2005 08/10/2004 4:16 AM
Junior Member
Junior Member
Thanks ......I'll due some scrap'in and try to find a number simular to CON4 and see what I come up with
smile
Quote
53 1/2-ton GMC 4x4
54 Chevy 1/2-ton
#2006 08/10/2004 4:59 AM
oops,,, :o
Fixed link
