6 members (55shaker, D B Cooper, GMCJammer51, TPR57C, dt235sd, 1 invisible), 254 guests, and 0 robots.
Topics128,095
Posts1,056,069
Members48,433
#200048 02/03/2006 5:16 PM
This might should be in the electrical but,,,
can you still buy those big red stop lights, that spell out STOP like in the old days? have not seen any in a long time, might want to try some out..Fred
Redryder pix
My Hotrod
#200049 02/03/2006 5:33 PM
I was behind a school bus this morning and when it stopped to pick up some kiddos a "STOP" sign popped out on the drivers side on a hinge and the word STOP had led lights in it.....
Like that Fred? : )
I'm kind of thinking that if someone behind you doesn't understand the concept of brake lights then they probably can't read "stop" : )
Besides, I like my blue dots!
Larry Bear
55.5 Chevy 3100 Panel
#200050 02/03/2006 5:33 PM
RT1 Offline
#200051 02/03/2006 7:02 PM
Randy, boy a little high, up to $47 bucks, but those are the ones I was speaking of....neat,,Fred
by the way, do you buy all your stuff on ebay?
Redryder pix
My Hotrod
#200052 02/03/2006 7:17 PM
RT1 Offline
Fred, I just keep looking there, sooner or later it will be in my price range. Its good to look on ebay to see what things are selling for, before you head out to the swap meets.
wink
Randy
#200053 02/03/2006 7:18 PM
good idea
Redryder pix
My Hotrod
#200054 02/04/2006 3:19 AM
Joker, I remember those lights as well. I remember them as being mounted in the center of larger trucks, under the bed. Maybe they were retrofits?
I remember them having a round metal housing and the word "STOP" stenciled on the lens, similar to some of those on eBay.
I always thought they were cool. Granted, as a practical matter, no one is going to read the word "STOP" and then decide to obey. But they are a nice nostalgic reminder of another time in my life.
#200055 02/04/2006 7:20 PM
My 46 2 ton has an arm with reflectors that is controled by cable and a lever with notches above the drivers window. When you put it in the first notch, it simulates a left turn hand signal and second notch, a right turn. It's pretty cool, but not sure many people know what a hand signal means anymore, heck, half the drivers I see don't even use thier signal lights!
You never have enough, til you have too many!
