4 members (Otto Skorzeny, KEVINSKI, k2handyman, Stovebolt48), 127 guests, and 2 robots.
Topics128,034
Posts1,055,552
#199994 02/03/2006 7:31 AM
my 235 has dual carbs and i really have to choke it in the mornings to get her to stay running. my problem is that when i pull out the hand choke it is super hard to get it to go back in. i have to take the palm of my hand and smack it to settle down. i would appreciate any suggestions on how to fix this problem. thanks alot tedjames
#199995 02/03/2006 8:28 AM
Junior Member
Junior Member
It sounds like your jamming up on something on your carb linkage or the cable is kinked. Check the cable from the pull to the carb for kinks as there should be no sharp bends (the straighter the better). Check that your carb linkage is free with the cable detached. You also might try spraying the cable with some WD40.
#199996 02/03/2006 1:51 PM
OK....
I understand the problem you have and the best solution that I can think of has already been suggested (some lubricant in the cable). I certainly don't want to detreact from that and hope you resolve your problem.
But I gotta tell ya that the topic of this thread is just plain funny.
Tilt your head back, cuz Mama Bird is going to ram a juicy nightcrawler of truth down your throat!
#199997 02/04/2006 7:11 AM
thanks for the help guys and what gave me away bout being a greenhorn on the subject. tedjames
