0 members (),
160
Mod | | | Forums66 Topics128,149 Posts1,056,818 Members48,456 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2005 Posts: 1,682 Extreme Gabster | | Extreme Gabster Joined: Jan 2005 Posts: 1,682 | I met up with a guy who's looking for 1940 fenders for a GMC truck he says is a 1 and a 1/4 ton.. and this truck is supposed to have I guess 16" tires on it.
My question is, did GMC use the same size fenders on all their trucks in '39 and '40? If they used larger fenders for the larger trucks, at what size did they start using them?
If it helps, he says his 1 and a 1/4 ton truck has dulies on the back.. anybody know at what size dulies were used?
| | | | | Joined: Mar 2005 Posts: 170 Member | | Member Joined: Mar 2005 Posts: 170 | FWIW, My Canadian 1940 GMC is a 1 ton model 9400. I don't believe a 1 ton was offered in the US that year. From what I can tell, my 1 ton is basically a 3/4 ton with heavier rear springs and larger rear brakes and 17" wheels. Anyway, I'm pretty sure that the rear fenders on my 1 ton are the same as 1/2 and 3/4 ton. Steve | | | | | Joined: Nov 2001 Posts: 481 Shop Shark | | Shop Shark Joined: Nov 2001 Posts: 481 | Fumbling, my 39-40 GMC parts book shows two different front fenders available for the 39-40 AC series trucks. One fender for 1/2 and 3/4 tons and another for 1 ton and larger. | | |
