| | | Forums66 Topics128,185 Posts1,057,205 Members48,465 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2006 Posts: 5 Junior Member | | Junior Member Joined: Jan 2006 Posts: 5 | Any one know how to get this bugger out? I have tried putting pins in the holes beside the key to no avail. any insight or instruction is appreciated. :confused: | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | Turn it to "on" or "acc" before putting the pin in. | | | | | Joined: Jun 2005 Posts: 209 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 209 | | | | | | Joined: Mar 2005 Posts: 576 Shop Shark | | Shop Shark Joined: Mar 2005 Posts: 576 | i agree with cletis, its been awhile since i had one out but i think it was turn to acc stick the pin or paper clip in turn it just a touch and it should come right out. good luck 1949 Chevrolet 3100 "When this thing hits 88 miles an hour, you're going to see some serious sh%t." -Doc Brown
| | | | | Joined: Feb 2005 Posts: 199 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2005 Posts: 199 | I agree with cletis also. Turn to acc,feel around with a paper clip while pushing in and you will feel the spring give and while holding that spring in turn the key on past acc while pulling gently on the key and it should come out.
Aggravating little booger!!!!
Hobert
"The Lord is my shepherd"
| | | | | Joined: Jan 2001 Posts: 613 Member | | Member Joined: Jan 2001 Posts: 613 | i tried a while back.i gave up. | | | | | Joined: Jun 2005 Posts: 209 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 209 | Agrees with himself.  | | |
