1 members (Hotrod Lincoln),
72
0
Mod | | | Forums66 Topics128,049 Posts1,055,680 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2006 Posts: 10 Junior Member | | Junior Member Joined: Jan 2006 Posts: 10 | Does anyone know how to tighten up a steering column? Not the actual column itself, but the shaft inside it. Currently, I can move my steering wheel in and out about an inch (Not good.) But it steers fine. Is there an adjustment nut under the hood, or is it in the column in the cab? Your help is appreciated. | | | | | Joined: Sep 2005 Posts: 96 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2005 Posts: 96 | you'd probably have to replace the bushings in the shaft. they're pretty worn from 50 odd years of use | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | yeah, the steering box needs a rebuild, where there'll be bearings to replace
Bill | | | | | Joined: Sep 2003 Posts: 343 Member | | Member Joined: Sep 2003 Posts: 343 | Sounds like you need to tighten the worm shaft adjustment screw on the end of your steering box.
Jim
1954 GMC 1/2-ton Longbed 1971 Pontiac LeMans Sport
