4 members (walter74, 32Fordpuchoptop, Hotrod Lincoln, 1 invisible), 111 guests, and 1 robot.
Topics128,035
Posts1,055,443
Members48,422
Junior Member
Junior Member
Does anyone know how to tighten up a steering column? Not the actual column itself, but the shaft inside it. Currently, I can move my steering wheel in and out about an inch (Not good.) But it steers fine. Is there an adjustment nut under the hood, or is it in the column in the cab? Your help is appreciated.
you'd probably have to replace the bushings in the shaft. they're pretty worn from 50 odd years of use
it's not old it's "aged to perfection"
http://brent5631.myphotoalbum.com/
yeah, the steering box needs a rebuild, where there'll be bearings to replace
Sounds like you need to tighten the worm shaft adjustment screw on the end of your steering box.
Jim
1954 GMC 1/2-ton Longbed
1971 Pontiac LeMans Sport
