6 members (TUTS 59, Ponchogl, Steelonsteel, Gdads51, Gray_Ghost, ESum), 92 guests, and 4 robots.
Topics128,088
Posts1,056,125
Members48,435
#198962 01/21/2006 3:52 AM
Junior Member
Junior Member
Bought a chevy pickup with a 1954 235 engine.It has a 3speed on the floor and a open driveshaft.I want to get the moter redone this winter and go over the complete drive train.I know the drive shart is not original, but the tranny and the rearend I dont know? Did they make a 3speed?Ande the rearend I would like to gear up because it pulls 3grand at 55mph.
Jim Geurts
#198963 01/21/2006 4:52 AM
that is a cool truck, they did make the three speed, but i am not sure if it is origional without knowing your vin and particulars. good find and keep us posted on how it goes.
"Never tell people how to do things. Tell them what to do and they will surprise you with their ingenuity." - George S. Patton
My Machine
#198964 01/21/2006 5:56 AM
I understand it is a 49 with a 54 motor in it. If it has an open drive then both the trans and differential are not original. You could have the original rear axle but with an open drive the third member could be from a bit later truck. All 49 half tons had closed (torque tube) drive.
1949 Chevy 1/2-Ton
"Sedgewick"
1989 Caprice
#198965 01/21/2006 10:12 AM
Junior Member
Junior Member
I do not have the motor pulled yet because I broke my leg.I want to do a full restore but I want to drive it in summer so I thought if I do the drive train this winter(late start) and then next winter do a down to the frame restore.Want to keep the truck as original as I can yet make it hiway drivable and trust worthy.Buy the way I am in love with this truck.Dont tell my wife!
Jim Geurts
#198966 01/21/2006 3:29 PM
24601
Jim -- Welcome both to the Stovebolt Page and to the Old Truck hobby!!! Sounds like you got it bad. No worries, you're among friends here. Some of us (them), believe it or not, have it worse than you!
Are you sure it's a '49? Hey guys, didn't the early '47s have the floor-shifted 3-speed? (and was it a closed driveshaft?)
Jim -- keep coming back with your questions and we'll get you going. Make sure you read through the rest of the site, too. We are here for you!
Welcome aboard!
~ John
1949 Chevrolet 3804
1973 IH 1310 Dump
1963 Kaiser M38A1
2014 Ford E-350 4x4 (Quigley)
#198967 01/21/2006 4:22 PM
oldblu49 has it right, assuming that Jim G's truck is a '49 3100 (1/2 ton). If the truck has an open driveshaft, then the transmission, driveshaft, and rear end are not original. However, that combination might have gearing that will give you better hiway driving.
1947 was the last year that the three-speed transmission used floor shift, and the last year that the 1/2 ton parking brake was activated by a lever next to the floor-shifter. After-market floor shifter adapters were available for many 3-speed transmissions (I remember them in JC Whitney catalogs).
Tim
