1 members (baldeagle), 108 guests, and 7 robots.
Topics128,014
Posts1,055,328
Members48,419
#198901 01/20/2006 4:07 AM
Can someone give me the size of the so called big back window of a 66 cab? Does it wrap around the back of the cab?
Shoundog
Doug
#198902 01/20/2006 4:47 AM
No, it doesn't wrap around. If you look at a small window cab, you will see an indentation around the small window. If you were to cut out everything inside that indentation, that's how big the larger rear window are. Hope I explained it clear enough,
Scott
Scott Ward
2 1948 1.5-ton Loadmasters
1 1950 3100
1 1955.1 Chevy 6500
1 1954 Chevy 6500 2-Ton
1 1955 1st Series COE 5700
1 1963 K20 (454)
1 1964 C10 (350)
1 1951 1.5-ton Dump Truck
1953 and a 1956 Ford F800
#198903 01/20/2006 5:47 AM
