5 members (UtahYork, Jeff Ogden, Maybellene, KEVINSKI, MikeStone1953), 343 guests, and 6 robots.
Topics128,159
Posts1,057,029
Members48,460
Started wrenching on my '89 Chevy 2500 truck last week...this is the newest Bow-tie I've ever touched, so please pardon my "ingorance"...
WHO at GM came up with the brilliant idea to put 9/16" hex flare-nuts on 3/16" brake-line tubing ???? :mad:
Not only did the flare-nut wrench begin to round the corners on the 9/16" nut-heads, but 2 out of 3 wrung the hex off, leaving the threaded stub (and line) tightly buried in the wheel-cylinders and brake hose.
While this is certainly not my first experience with crusty brake plumbing, this is the first time I've run into these B-A flare nuts, and I don't think I like them !
I needed to replace the lines on the rear axle and the rear WC's any way, so it's not the end of the world...but I will be putting back lines with regular-sized 7/16" hex flare nuts...
Thank goodness the fitting from the main line into the rear brake-hose came loose...
Once again, I'm a victim of "Progress" !
:p
Frank McMullen
1941 Chevy dump truck
1949 GMC 100 pick-up
1954 Chevy 3600 pick-up
1955.1 4400 dump truck
1941 De Soto & other MoPars
1928 Model A F**D Special Coupe
Frank,
I'm innocent. I always use vise-grips to bust the fittings loose, then you can use a flare nut wrench. My experience has been a flare nut wrench will not break a tight nut loose..only round it over. I was hung-drawn-and quartered for my opinion on this subject, but I'm sticking to my guns.
Remember as you work on the newer rigs, all engineering decisions are based on $$$. Somehow, it was more cost effective for GM to use that size flare nut.
Stuart
atomarc is got it right.. it's all about saving a nickle.. or even a half a penny sometimes.
Dosen't sound like much difference, a half a cent.. but when you multiply that by a dozen or so then multiply that by the millions of vehicles they sell, it adds up.
My first experiences with wrenching on cars were the late 70's models.. and I found the newer they got the more confusing and just in general pains in the [censored] they were.. makes me appreciate working on my 60 year old trucks all the more.
A proper wrench and a GOOD wrench help a lot. Since it's an '89, it could have been a metric nut. A flare nut wrench should fit extremely snugly. Cheaper brand wrenches usually don't.
I don't know...my HF flare wrenches fit very snugly around flare nuts. On older stuff, I always just used a pair of vice grips and start replacing lines.
1954 GMC De Luxe COE
i had a 92 and ran into the same problem. i replaced the lines with some braided stainless lines. i ended up re-engineering so much crap on that thing that i got rid of it because i hated working on it, i think that made them hard to work on on purpose. that way i have to take it to the dealership. i sold that bucket down the road and bought my '61, which i could take completely apart with a socket set, some wrenches and a pair of screwdrivers. of course my 61 has those dumb clutch head screws but that is my only pet peeve thusfar and they aren't really that big of a deal once you buy the clutch drivers. anyway my advice is to get ready to run into a lot of backwards engineering. it was what ultimately made me get rid of mine. i liked it but i could not work on it effectively. i have run into the same situation with many new vehicles, which just reinforces my love of old and easy to to work on vehicles.
"Never tell people how to do things. Tell them what to do and they will surprise you with their ingenuity." - George S. Patton
My Machine
want a GREAT flare nut wrench? Cornwell makes a set of 3/8" crowfoot flarenut wrenches that are the bomb! I used them for years in the garage where I worked,and they're beefy enough that they just don't flex. I was amazed at how well they worked,and I tried Snap On,Craftsman,Proto,S-K,but so far,Cornwell beats 'em all. (haven't tried MAC yet,my bro says they're good too.) One trick is making sure you get a good straight pull on the wrench;if the wrench tips at all from straight,it'll slip. Get your wrench aligned and hold a little pressure on it to keep it located,then give it a smack with your othewr hand to overcome the "sticktion" that keeps the nut tight. It should pop loose.I'd also used a small C-clamp on the jaws of the wrench to keep them from spreading and slipping on the nut,before the "good" wrenches.
Speed
1954 GMC 350
1957 GMC 1/2 ton
1962 Chevy C-30
'98 Harley FLSTC
'66 Pontiac Catalina
'76 Chevy 1 ton Duallie
'84 Bronco II
'78 Dodge W-200
'81 Toyota 4X4 truck
