| | | Forums66 Topics128,042 Posts1,055,519 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2003 Posts: 343 Member | | Member Joined: Sep 2003 Posts: 343 | A fellow stovebolter is interested in buying a 248 Crankshaft that I have and we were both wondering what the best way to ship this heavy item with out damaging it in the process. I think it is already too heavy for UPS to handle even w/o packing it up for safe shipping. I have heard of shipping big heavy items on buses before, but I have never done this. As far as packaging this, I feel that a cardboard box and packing peanuts would not be up for the task. I think that it should be crated, but I do not know if strapping it to a board inside the crate is good enough or would it be better to make wooden journals to support the crank on its journey to its new owner. What do you folks think? Thanks.
Jim
1954 GMC 1/2-ton Longbed 1971 Pontiac LeMans Sport
| | | | | Joined: Jan 2005 Posts: 24 Junior Member | | Junior Member Joined: Jan 2005 Posts: 24 | Here's what I do on large heavy items...
Wrap them snugly in a plastic trash bag. Then, find a box that's large enough, and use spray can expanding foam to fill the voids around the part.
Works much better than peanuts.
Tender caretaker of antique tractors and old trucks.
| | | | | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | cujo,
This is what I think I know..UPS will take 150 lbs. If you crate it in wood, they will insist on your first born. If it is OS-1 or OS-2, drop off your wife AND first born.
If you weight the crank and it is light enough with the intended packing to meet UPS weight limits, strap it to a board and put it inside a cardboard box with stout material around it.
Tx Firefighter mentioned the foam which is a cool idea. If you decide on UPS, go to their website or a true terminal and get the dope on the oversize (OS) packages and special charges.
Your original thought on the bus might be worth investigation. We always used that method for heavy stuff when I was a "shop gofer".
Stuart | | | | | Joined: Sep 2003 Posts: 343 Member | | Member Joined: Sep 2003 Posts: 343 | I have not weighed the crankshaft, does anyone know how much one of these suckers weigh? I was thinking it might weigh ~ 80lbs, what do you guys think?
Jim
| | | | | Joined: Oct 2005 Posts: 4,249 "Hey! I sound like Darth Vader!! | | "Hey! I sound like Darth Vader!! Joined: Oct 2005 Posts: 4,249 | Heck, easy stuff! (I ship old bikes all the time. Even heavier stuff!!) Last time I shipped a crank ( small block chevy) I rolled it up in cardboard so it had three or four layers. Stuck a label right on it. Took it to the post office. I'd do the same with UPS. Just make sure that cardboard hangs off the end a few inches for end cushioning!. Squeeze it together and tape well. | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | So how does this heavy shipping work? I would assume that over 50 lbs, the shipper uses some kind of hoist? | | | | | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | truckernix,
I don't know about all shippers, but UPS puts a label on the package that says "heavy"...that's it!
Stuart | | | | | Joined: Jan 2002 Posts: 244 Shop Shark | | Shop Shark Joined: Jan 2002 Posts: 244 | Hey use Greyhound. I've shipped doors, front fenders and a front seat for a '56 PU...no problems  . | | | | | Joined: Feb 2002 Posts: 2,893 Socket Breaker | | Socket Breaker Joined: Feb 2002 Posts: 2,893 | http://www.freightquote.com/ a pal of mine I know that runs a machine job shop with his brother, they use this site to ship the metal thingymajingys they make all over the place. -W | | | | | Joined: Oct 2005 Posts: 4,249 "Hey! I sound like Darth Vader!! | | "Hey! I sound like Darth Vader!! Joined: Oct 2005 Posts: 4,249 | Originally posted by truckernix: So how does this heavy shipping work? I would assume that over 50 lbs, the shipper uses some kind of hoist? Most times, the job specs require that a person can lift up to 100 lbs in the course of their job. Most UPS drivers make full use of their hand trucks. | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | That is very interesting. I wish that we had shippers like that! Up here most employers cannot ask a person to lift more than 50 lbs! I don't know what they do with mechanics. | | | | | Joined: Apr 2003 Posts: 608 Shop Shark | | Shop Shark Joined: Apr 2003 Posts: 608 | For info to all UPS 1-800-742-5877 You will need zip from and to Approx weight length,width and height of pkg | | | | | Joined: Apr 2003 Posts: 608 Shop Shark | | Shop Shark Joined: Apr 2003 Posts: 608 | More Info to All US Shipping / Phone# / Steps to Find a Human DHL 800-225-5345 press1 press5 press0 enter your phone# FedX 888-463-3339 At message say "rep" or press 0 Union Pacific 800-877-5123 press# during main menu options UPS 800-742-5877 press 0,0  Hope this helps cujo and others Regards | | | | | Joined: Jan 2005 Posts: 1,682 Extreme Gabster | | Extreme Gabster Joined: Jan 2005 Posts: 1,682 | I had no idea that a crank weighed that much.. I would have thought maybe 25 to 30lbs tops.
| | | | | Joined: Sep 2003 Posts: 343 Member | | Member Joined: Sep 2003 Posts: 343 | Well I just weighed the 248 crank on the wifes bathroom scale (Don't Tell Her) and the crank weighed in at 75lbs. Here's a link to a picture of the crank if your interested: http://community.webshots.com/photo/541778765/541778765chXkic
| | | | | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | cujo8, UPS has a website where you can plug in weights, package size, destination etc and come up with a shipping price. I even generate my own shipping labels and arrange for pickups without lifting my butt out of the swivel chair. Stuart | | | | | Joined: Jan 2002 Posts: 244 Shop Shark | | Shop Shark Joined: Jan 2002 Posts: 244 | Here's the UPS site. Here's the DHL site. I've heard DHL is cheaper. | | | | | Joined: Oct 2005 Posts: 4,249 "Hey! I sound like Darth Vader!! | | "Hey! I sound like Darth Vader!! Joined: Oct 2005 Posts: 4,249 | Originally posted by atomarc: cujo8,
Stuart When you use the calculator at the UPS site, add a few bucks to the total. Seems that when you make an actual shipping label, they are always a few bucks more than what they quoted. I ask UPS customer service about this and they never did give meman answer. | | | | | Joined: Sep 2003 Posts: 343 Member | | Member Joined: Sep 2003 Posts: 343 | Thanks for all the good info and links guys.
Jim
