1 members (RLB),
215
Mod | | | Forums66 Topics128,094 Posts1,056,066 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2006 Posts: 3 Junior Member | | Junior Member Joined: Jan 2006 Posts: 3 | I have a 1983 Chey 3/4 ton 4x4 pick-up with 129,000 miles on it. At low speeed it developes a very bad shimmy where the whole truck shakes and feels like I'm going to loose control of it. I replaced the front shocks and the stablizer shock a year ago, and that seemed to resolve the problem until about 2 weeks ago.. Now, I'm afraid to drive it until this problem gets fixed. Any sugesstions? Thanks, Perry [email protected] | | | | | Joined: Jul 2005 Posts: 1,158 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 1,158 | So, just to be clear, this is a "I canna doooo it, Captain! We dooona have th' poooer!" kind of a shimmy, right?
The only thing that I can think of is maybe if your wheels aren't on tight enough, or your tires are out of balance.
Are your wheels packed with snow? That will throw things into a wicked shimmy at all speeds.
Does your truck have Idler arms? If yes, are they worn out? We had a big van that developed that issue. It pulled to the right when you slammed on the brakes. Anything like that?
Is it stuck in 4WD and doing the "Crab Walk"?
Are your tires old and misshapen?
I'm sure that I can think of other things to check, but I am drawing a blank right now. | | | | | Joined: Jan 2006 Posts: 17 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2006 Posts: 17 | might sound dumb, but check oyur power steering fluid
There is a great demand nowdays for people that make failure look like success. "They that can give up essential liberty to obtain a little temporary safety deserve neither liberty nor safety." [ Benjamin Franklin ]
"Above all nations is Humanity" [Inscribed on a bench I saw] | | | | | Joined: Sep 2004 Posts: 235 Shop Shark | | Shop Shark Joined: Sep 2004 Posts: 235 | Sounds like one of your axle joints are binding on you. They are probably rusting up and need to be replaced. | | | | | Joined: Oct 2000 Posts: 112 Shop Shark | | Shop Shark Joined: Oct 2000 Posts: 112 | Pery, see engine drive train for reply to your question. jbennett 40 burb | | |
