4 members (Peggy M, Gib70, Shade Baby, MickeyP), 47 guests, and 2 robots.
Topics128,090
Posts1,056,014
Members48,430
#197579 01/08/2006 9:50 PM
Junior Member
Junior Member
I have a 1983 Chey 3/4 ton 4x4 pick-up with 129,000 miles on it. At low speeed it developes a very bad shimmy where the whole truck shakes and feels like I'm going to loose control of it. I replaced the front shocks and the stablizer shock a year ago, and that seemed to resolve the problem until about 2 weeks ago.. Now, I'm afraid to drive it until this problem gets fixed. Any sugesstions? Thanks, Perry
[email protected]
#197580 01/08/2006 10:01 PM
So, just to be clear, this is a "I canna doooo it, Captain! We dooona have th' poooer!" kind of a shimmy, right?
The only thing that I can think of is maybe if your wheels aren't on tight enough, or your tires are out of balance.
Are your wheels packed with snow? That will throw things into a wicked shimmy at all speeds.
Does your truck have Idler arms? If yes, are they worn out? We had a big van that developed that issue. It pulled to the right when you slammed on the brakes. Anything like that?
Is it stuck in 4WD and doing the "Crab Walk"?
Are your tires old and misshapen?
I'm sure that I can think of other things to check, but I am drawing a blank right now.
#197581 01/08/2006 10:06 PM
might sound dumb, but check oyur power steering fluid
There is a great demand nowdays for people that make failure look like success.
"They that can give up essential liberty to obtain a little temporary safety deserve neither liberty nor safety." [ Benjamin Franklin ]
"Above all nations is Humanity" [Inscribed on a bench I saw]
#197582 01/08/2006 10:52 PM
Sounds like one of your axle joints are binding on you. They are probably rusting up and need to be replaced.
#197583 01/09/2006 12:45 AM
Pery, see engine drive train for reply to your question.
jbennett
40 burb
