0 members (),
38
Mod | | | Forums66 Topics128,089 Posts1,056,004 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2004 Posts: 4 Junior Member | | Junior Member Joined: Sep 2004 Posts: 4 | My son just bought a 60 1/2 ton with a 350/th350 combo already installed. He is stressing out over the gas this thing drinks. We want to keep the 6-lug axle. I'm thinking a ration of around 3.08 would work well. Is there a simple (cheap) gear swap available? Are ring and pinion combinations available?
Thanks for the help. | | | | | Joined: Nov 2003 Posts: 11 Junior Member | | Junior Member Joined: Nov 2003 Posts: 11 | I was quoted a year or two ago 995$ by an axle shop to put in a posi carrier with new gears, bearings and seals. I'd bet that it is even cheaper if you opt for a conventional differential. | | | | | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | I once owned a '70 Blazer that had 3.08 gears. It was a factory arrangement and took six-lug wheels. If you could find something like that it might be an easy swap.
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | | | | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | There should be a ring and pinion available somewhere for that axle, I have a '66 six-lug axle that the previous owner swapped a 3.07 into, and I think he paid $250 to have it done. Alternately you could put in a 700R4 tranny, it may be easier in the long run.
Paint & Body Shop moderator A lone amateur built the Ark. A large group of professionals built the Titanic. | | | | | Joined: Jun 2000 Posts: 2,773 'Bolter | | 'Bolter Joined: Jun 2000 Posts: 2,773 | I have 3.07 gears in my 69, with a 350/TH400. Get about 14 mpg on a good day. Too bad you're so far away, this winter I will be replacing it with a 3.42 posi 12 bolt rear end.
Fred 52 3600 69 C-10
#1977 09/07/2004 10:25 PM | Joined: Feb 2001 Posts: 4,095 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 4,095 | go to randysringandpinion.com for pricing on ring and pinion. the shop locally for same and labor separately. the site also has a calculator for ring and pinion ratios and tire size and rpms.
Ron, The Computer Greek I love therefore I am.1954 3100 Chevy truckIn the Gallery 2017 Buick Encore See more pix1960 MGA Roadster Sold 7/18/2017
| | | | | Joined: Sep 2004 Posts: 4 Junior Member | | Junior Member Joined: Sep 2004 Posts: 4 | Thanks to everyone for your reply. A freind has nearly got me convinced to go with an OD trans instead of gears. Anyone ever put the 700R4 in their 60 truck? Does this sound reasonable? | | |
