0 members (), 54 guests, and 3 robots.
Topics128,072
Posts1,055,906
Members48,429
#197357 01/06/2006 4:55 AM
Junior Member
Junior Member
doing brakes on my '52 3/4 ton. I want to put discs on the front. Is there a conversion out there I havn't found for this? Or something else that will work. I would like to keep as much of the original front end as I could, 8 lug wheels, straight axle, so on.
#197358 01/06/2006 5:07 AM
I'm not aware of any kit that will do this, but at least two people have made their own caliper brackets and have adpated disks to the front of one of these trucks.
In at least one case the disks were from a Dodge pickup and where fit onto the stock 1-ton hubs complete with dually adapters.
#197359 01/07/2006 8:40 AM
I had the same goal, so I went with kevlar brake shoes and they gave me a big improvement on the fronts on my 59. I wanted to keep my 1 ton load rating.
http://www.praisedynobrake.com/
A bit pricey for brake shoes, but cheaper than any conversion and a lot easier.
#197360 01/08/2006 1:34 AM
Junior Member
Junior Member
thanks for the heads up on the kevlar shoes, I will try those first with all new system and see what happens.
