1 members (1 invisible),
105
Mod | | | Forums66 Topics128,024 Posts1,055,395 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2002 Posts: 4,066 Bolter | | Bolter Joined: Oct 2002 Posts: 4,066 | thinking about useing the door panel where the piece is screw on at the bottom for storage of stuff, I suspose but not sure that this is what the removal panel at the bottom is used for..things that I might need for emergency such as belts or anything else that I might get in there,,anyone use these removal panels for storage? Redryder pixMy HotrodA veteran - whether active duty, retired, national guard, or reserve - is someone who, at one point in his or her life, wrote a blank check made payable to The 'United States of America', for an amount of "up to and including my life."I am fighting cancer and I am winning the fight | Pain is part of life; misery is an option. | | | | | Joined: Feb 2005 Posts: 399 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2005 Posts: 399 | That's a great idea, but I always kick that spot when I'm getting out..Would probably work for some small stuff that you forgot you put in there though.. Steve | | | | | Joined: Oct 2002 Posts: 4,066 Bolter | | Bolter Joined: Oct 2002 Posts: 4,066 | I may forget what I put in it, although it is a small area, still can get stuff in it,,like a raditor hose, fan belt, gas line rubber hose, plus you have one on each door.. tomorrow I will remove and see what all I can get in there,dont have a tool box and my handy dandy bag where I have tools and such is getting full.........Fred Redryder pixMy HotrodA veteran - whether active duty, retired, national guard, or reserve - is someone who, at one point in his or her life, wrote a blank check made payable to The 'United States of America', for an amount of "up to and including my life."I am fighting cancer and I am winning the fight | Pain is part of life; misery is an option. | | | | | Joined: Apr 2002 Posts: 1,571 Shop Shark | | Shop Shark Joined: Apr 2002 Posts: 1,571 | Be careful, you don't want anything clogging up the drain holes. If you do, it's instant rust. | | |
