6 members (1955 1 Series, Hotrod Lincoln, Eisenholtz, Otto Skorzeny, Hugh63c10, TUTS 59), 48 guests, and 2 robots.
Topics128,030
Posts1,055,418
Members48,422
#197259 01/05/2006 1:25 AM
thinking about useing the door panel where the piece is screw on at the bottom for storage of stuff, I suspose but not sure that this is what the removal panel at the bottom is used for..things that I might need for emergency such as belts or anything else that I might get in there,,anyone use these removal panels for storage?
Redryder pix
My Hotrod
#197260 01/05/2006 1:30 AM
That's a great idea, but I always kick that spot when I'm getting out..Would probably work for some small stuff that you forgot you put in there though..
Steve
#197261 01/05/2006 1:39 AM
I may forget what I put in it, although it is a small area, still can get stuff in it,,like a raditor hose, fan belt, gas line rubber hose, plus you have one on each door.. tomorrow I will remove and see what all I can get in there,dont have a tool box and my handy dandy bag where I have tools and such is getting full.........Fred
Redryder pix
My Hotrod
#197262 01/05/2006 3:18 AM
Be careful, you don't want anything clogging up the drain holes. If you do, it's instant rust.
1954 GMC De Luxe COE
