9 members (JoergK., Bill Hanlon, J Lucas, Chip O, dt235sd, Gdads51, Hotrod Lincoln, 2 invisible),
75
0
Mod | | | Forums66 Topics128,205 Posts1,057,427 Members48,471 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2005 Posts: 640 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 640 | I'm getting ready to put my truck back together, and while I did a fairly good job of labeling a lot of stuff when I took it apart 15 years ago, I didn't do so well with the various body bolts. What size nuts and bolts should I buy for the front fenders, inner fenders, etc? Is there a place I can go to find this type of information? The assembly manual doesn't seem to have it.
:confused: | | | | | Joined: Jul 2005 Posts: 2,031 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 2,031 | Some are 5/16'' or 3/8'' x 1'' and 1 1/4''x 18 or 16, course thd. You could probably get away w/ 3/4'' or 7/8'' w/ the captured nuts for the inner fenders and firewall. I'd also use a nyloc and washers of course then use the longer bolts. That way there wouldn't be vibration causing nuts to loosen.
Jim & Caroline The highway is for gamblers, better use your good sense." Gooday-that's my 1¢ answer due to the lousy economy ~ cause I ain't got - no . mo . doe Every Shaver | Now Can Snore | Six More Minutes | Than Before ... | Half A Pound for Half a Dollar | Spread On Thin | Above the Collar || BURMA-SHAVE
| | | | | | Anonymous Unregistered | | Anonymous Unregistered | The bolt set I got for my 54 were 3/8-16. The parts houses have a bolt kit you can buy either in stainless or zinc that have all you need. That is the way to go IMO. | | |
