0 members (), 35 guests, and 3 robots.
Topics128,014
Posts1,055,327
Members48,419
#19679 01/09/2005 5:53 PM
What is the correct seting for the timing gears on a 216?
My book only says they should be opposite one another.
I put my motor togather acording to the manual and ran into all sorts of problems along the way. The manual doesn't address shims, torking bolts, or clearly addressing timing marks. I was going to take my truck out last sunday but insted I bent some rods.
1956 Chevy 3600
“Maynard”
In the DITY Gallery
More pictures on Flickr
#19680 01/10/2005 10:42 AM
The gears have a little circle on them, those are your marks. When you slide in the cam make sur the circles meet each other. That`s all.
Bent or broken pushrods sound like wrong installed cam (timing) or fu..ed up cam gear. The fiber geares are prone to break. get a aluminum one next time.
Hope this helps.
#19681 01/11/2005 1:02 AM
Thank you. It does work better this way.
Bart
1956 Chevy 3600
“Maynard”
In the DITY Gallery
