| | | Forums66 Topics128,012 Posts1,055,316 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#19679 01/09/2005 5:53 PM | Joined: Mar 2004 Posts: 208 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 208 | What is the correct seting for the timing gears on a 216? My book only says they should be opposite one another. I put my motor togather acording to the manual and ran into all sorts of problems along the way. The manual doesn't address shims, torking bolts, or clearly addressing timing marks. I was going to take my truck out last sunday but insted I bent some rods. | | |
#19680 01/10/2005 10:42 AM | Joined: Aug 2004 Posts: 399 Shop Shark | | Shop Shark Joined: Aug 2004 Posts: 399 | The gears have a little circle on them, those are your marks. When you slide in the cam make sur the circles meet each other. That`s all.
Bent or broken pushrods sound like wrong installed cam (timing) or fu..ed up cam gear. The fiber geares are prone to break. get a aluminum one next time.
Hope this helps. | | |
#19681 01/11/2005 1:02 AM | Joined: Mar 2004 Posts: 208 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 208 | Thank you. It does work better this way.
Bart | | |
