| | | Forums66 Topics128,127 Posts1,056,357 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#1967 03/27/2002 10:39 PM | Joined: Jul 2001 Posts: 149 Member | | Member Joined: Jul 2001 Posts: 149 | Engine hunting! Iam looking for a SBC 350 or 400. I want one complete so I will have all the brackets and pully and stuff. First how can you tell a 350 from a 400?? I know there arent many 400's out there. Second What are some things I need to look for when choosing a engine that still in the car or out of the car with all the stuff still on it? Is there a visual way to tell if the block is cracked? Can you tell if its a 4 bolt or a 2 bolt main with out pulling the oil pan? Tips suggestions anything will help. Thanks!
"Finish the thing, do it right the first time, and drive the S.O.B.!"
1949 Chevy half ton 3100 In a kazillion pieces 2000 GMC Serria 1500 SL 4x4
| | | | | | Anonymous Unregistered | | Anonymous Unregistered | If you are in doubt about a good one, look for a wrecked vehicle. side impacts usually leave the motor in good shape. Big pickups w/smallblocks are often worked hard, but low milage wrecked donors are out there. sportscars can yield powerful mills, but are often high miles.. A full size car would be a good candidate. Others will have suggestions as well | | | | | Joined: Jan 2002 Posts: 398 Member | | Member Joined: Jan 2002 Posts: 398 | Mallard-can't answer ALL of your questions, but I might be able to help with a couple. First off, when you go huntin', take your trusty tape measure along. When looking for a four bolt main 350, TO THE BEST OF MY KNOWLEDGE, you need to measure the harmonic balancer on the crank snout (front of engine). One with a diameter of 8" across is generally a four bolt main crank, unless someone switched the balancer. If you are looking for a 400 small block, again your detective work should lead you to the harmonic balancer. The 400 small block Chevrolet is EXTERNALLY balanced, which means that it's harmonic balancer has scallops and/or drilled holes around the outside surface for balancing purposes-it's not completely round like most typical small block Chevy balancers are. I agree with Mr. Arends-look for a big sedan with a side punch. Another tip-look for out of the way yards in your area. This way you have a better chance of finding the older vehicles which more frequently came with the type of engine you are looking for. Happy hunting, Mallard! Wannabe
"Don't expect anything and you'll never be disappointed"
| | | | | Joined: Feb 2001 Posts: 1,094 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 1,094 | The harmonic balancer and the flywheel are externally balanced, you will see that right away. If my foggy memory serves me right you will notice the 400 had a different setup for the freeze plugs on the side of engine, don't remember exactly (it's been a LONG time )but I think that they only had 2 on a 400 and maybe it didn't have freeze plug under engine mount.
Tommy 59 apache 1/2t 261 short stepside | | | | | Joined: Jul 2000 Posts: 962 Shop Shark | | Shop Shark Joined: Jul 2000 Posts: 962 | Bring along a casting number list, as many different engines look the same. If looking at an old black funk-colored engine, it'd be hard to tell if it was a 307-327-350. The casting number on the bellhousing flange will tell you. You can also tell the hi-po mills by bringing your head casting lists. If you find any camel-hump or high perf heads, and you can get them reasonable, buy them!
Always check the muscle/sportscar castings! Most of those cars are on their 2nd or 3rd truck/sedan engine by the time they are junked.
good hunting!
chip
Preaching the Hot Rod Gospel according to the 4-stroke apostles:
Suck, Squish, Fire and Fumes
