3 members (Rich'sToys, Ponchogl, Peggy M), 332 guests, and 1 robot.
Topics128,081
Posts1,056,077
Members48,434
#196530 12/28/2005 2:50 PM
I have a 327 with double hump heads. Its been sitting in my garage for years. Do any of you guys know of a web site where I can type in the numbers off the heads and block and find out what the motor consists of.
Roger
http://www.flickr.com/photos/45469713@N00/?saved=1
#196531 12/28/2005 3:16 PM
#196532 12/28/2005 7:50 PM
Socket Breaker
Socket Breaker
Yeah, what toms68cst wrote.
Except you'll hafta read down the list of numbers. But it's in there.
-W
#196533 12/28/2005 9:57 PM
Thanks Guys,
I found the block casting number for the block. But that number is also listed for a 302 & 350. The left and right head have two different numbers. But I could not find either number on the Mortec web site.
Block-3892657
L/Head 3890482
R/Head 3891492
Maybe you guys will have better luck.
I did find the intake casting number on a different web site, and it is for a 327.
Roger
#196534 12/28/2005 10:39 PM
Riding in the Passing Lane
1972 Chevy c10 Cheyenne Super
#196535 12/29/2005 3:39 AM
DOOP, mismatched heads.. better just crate it all up and send it my way.
Another quality post.
Real Trucks Rattle
#196536 12/29/2005 5:08 PM
The block looks like a 64-67 small journal 302 or 327 CID. Couldn't be a 350 I don't think.
Are your sure one of your heads is not a 3890462? I don't see 3890482 listed.
Are your sure the other one is not a 3891462? I don't see 3891492 listed.
Either one of those heads could be correct for a 64-67 327. The 3890462 sounds like more of a HP head. Do the casting symbols match each other?
#196537 12/29/2005 5:12 PM
If you have a few extra bills lying around the "Chevy V-8 engine casting numbers 1955-93" Book is a VERY good investment. It'll explain all the little differences to look for as well as how to interpret date codes and such. It's also good read on the history of the Chevy SB.
#196538 12/29/2005 10:10 PM
Thanks for the info guys!
Im pretty sure the numbers I have given you guys are correct. I will check one more time!
Roger
Roger
