Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
2 members (MNSmith, Phak1), 120 guests, and 6 robots.
Topics128,284
Posts1,058,528
Members48,490
#196439 12/27/2005 8:49 PM
Junior Member
Junior Member
I purchased a truck which was represented to be a 65 chevy. From looking at pictures it would seem to be from the 64-66 range with one odd exception. This truck has a wrap around back glass, was this even available during these years. The truck is stored, out of state so I can't get any of the numbers off of it. Any help would be greatly appreciated.
#196440 12/27/2005 11:05 PM
6 heaven
6 heaven
I have a 66 that has a large back window. That was called the custom cab, I think. In order to tell the year model without the serial is hard, but the 66 did have backup lights. Also the model designation- 10 series- chrome emblem was in different places for 64, 65, 66 on the front fender side.
#196441 12/27/2005 11:10 PM
do you have any pictures you could show us? i do not know of any wrap around rear glass in those years. if its a 60s model the similarities would be from 60-63 with wrap around front glass. 64-66 no wrap around front glass. 60-61 had distinctly different hoods while 62-66 all had basically the same hood. also the grille and headlights can help identify. 60 and 61 has 2 headlights on each side. 62 has single headlamps on each side with an oval shaped bezel. 63 had round headlight bezels while 64-66 had square. 61 is quite noticeable with the in hood turn signals housing bearing the bowtie design. below is a list of examples of each year.
Hoods and front grille examples
1960: http://web.engr.oregonstate.edu/~merriss/Pictures/Truck%20At%20Sunset.jpg
1961: www.stovebolt.com/gallery/shott_mike_1961.htm
1962: http://www.zianet.com/SLlover/we62ChevyPU.JPG
1963: http://www.classiccars.com/classifieds/images/73/7321-23197lg.jpg
1964-66: http://pigeonmaster1.tripod.com/u21.jpg
windshield examples
1960-63: http://www.americandreamcars.com/1963chevytruck012704.jpg
1964-1965: http://pigeonmaster1.tripod.com/u22.jpg
many more examples can be had by our gallery here: http://www.stovebolt.com/gallery60-66.htm
hope this all helps.
#196442 12/28/2005 1:19 AM
Z
Z Offline
no chevy truck from 1960-66 had a curved rear glass.
#196443 12/28/2005 2:35 AM
the side emblems where all in different places and different disigns
'60 it said Chevrolet with Apache and model number below it was on the rear of the front fender
'61 it said Apache and model number it was on the side of the hood
62 had the bowtie then model number it was on the piece behind the hood
'63 had the bowtie with model number on top of it on the rear part of the front fender
'64 had the bowtie with the model number below was also on the rear part of the front fender
'65 had the bowtie then the model number beside it inside of rectangular area and it was on the piece behind the hood
'66 had the bowtie emblem on top of the model number inside a square box and was on the rear part of the front fender
Nate
(i did a power point project on how to tell the difference between '60-'66 chevy trucks)
Link to my photobucket for pics of my vehicles
http://s238.photobucket.com/albums/ff17/OldIronChevy/
#196444 12/28/2005 7:06 PM
all you got to do is look at the emblem on the side thats how I tell right away..
1966 Chevrolet C-10
1971 Chevrolet Camaro RS
1989 Pontiac Bonneville
MY GARAGE...www.dragcitygarage.com
#196445 12/28/2005 11:47 PM
My '52 1/2 ton 5 window has a 350 SB/350TH & rearend from a '77 Blazer and runs great even though the engine could stand a little 'freshening'.
I am presently installing power steering and front power disks now that my 'honey do' landscaping project from He#@ is completed.
I want to keep the cab/exterior as original looking as possible by using the original steering wheel and column. I want a floor shifter that sort of looks like an original 4 speed and would also like to add a foot starter for the 'cool' factor, but therein lies a couple of questions that I am sure someone smarter than me has already figured out.
1. Has anyone used a Lokar or Gennie nostalgia shifter, and what length, 16" or 23"? Are they 'frail' that you have to baby them when you shift into gear and does the ignition lockout switch work effectively?
2. Presently the starter is activated by the ignition switch so does anyone know where I can find/make the linkage for a foot starter? I don't need the Bendix linkage, just enough to mount the pedal and I'll rig the switch myself.
I will appreciate any suggestions or help you can offer as you guys are the greatest source of collective knowledge I have run across yet and I'm sure I can get some real answers.
Thanks in advance for your help.
'52 Ted
illegitimi non carborundum
#196446 12/29/2005 1:48 AM
Ted, I dont know about adding a foot starter if you didnt have one to begin with but as far as the lokar and genie shifters they are good products. Ive used both in the past in my trucks and cars. They are nice looking and are very strong and the neutral switches work well. You have to measure up from your trans thru the floor up to where you hand would be to shift to tell whats comfortable for you to drive and shift.
#196447 12/29/2005 8:00 AM
1955 Had a wrap around back glass, 1965 had either a small or big back glass, the big back window was called the Extra View on the GMC options list, and it was NOT part of the custom package, you had to pay extra for it, about $40.
#196448 12/29/2005 8:13 AM
My Dad had a 66 Chevy with a full glass but I don't think it was curved.
Cliff59
Deluxe \'52, Savoy \'54 Apache59
"She may not be the youngest girl at the ball, but she can still turn a head or two."
