| | | Forums66 Topics128,094 Posts1,056,483 Members48,444 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2005 Posts: 34 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2005 Posts: 34 | Whoops!
I knew my 1947 panel truck's true name should be Rattle-Shake since all four doors bang in harmony over every sewer lid (the rubber is almost completely gone).
Today I discovered that below the windshield frame (A-pillar), the body has cracks in the metal on both sides. On the left it extends from about the windshield wiper to the upper door hinge and is completely cracked through. On the right it is smaller, but still significant. Amazingly, both doors close perfectly.
Does anyone know where this comes from? The area is not even rusty. Is that a Panel issue due to the huge body? And how should I fix it so it won't come back?
Thanks for any help,
C.Andyman
P.S.: Pictures of my Panel 'Monster' are now in the gallery. | | | | | Joined: Dec 2004 Posts: 425 'Bolter | | 'Bolter Joined: Dec 2004 Posts: 425 | They are stress cracks. Weld them up completely and you should not have any problems. | | | | | Joined: Mar 2004 Posts: 3,068 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 3,068 | Mine had lead in these areas as body filler. I just roughed it up with a body grinder and filled it with plastic body filler. Take some paint off of that area and see if it's lead or not, Scott | | | | | Joined: Aug 2001 Posts: 258 'Bolter | | 'Bolter Joined: Aug 2001 Posts: 258 | Ditto Scott's suggestion...
There is a factory seam right at this point that was originally filled with lead.
This may be more prone to cracking on the panel/ burb than on pick-ups due to the extended body having to cope with the frame twisting over the entire legth of the vehicle.
What kind of shape are your body-mounts in ? I have also observed that the early AD pick-up cabs (with the 3-point mounting) tend to crack in weird places: such as the dash-board, right above the steering column.
I guess this is why they redesigned the cab mounting to the four-point deal in '49(?)...
Frank McMullen 1941 Chevy dump truck 1949 GMC 100 pick-up 1954 Chevy 3600 pick-up 1955.1 4400 dump truck 1941 De Soto & other MoPars 1928 Model A F**D Special Coupe
