Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
4 members (Hotrod Lincoln, Otto Skorzeny, Phak1, Gdads51), 56 guests, and 0 robots.
Topics128,007
Posts1,055,278
Members48,418
#196050 12/22/2005 9:53 PM
engine number 1952 GM # 3835909 GM 11 What is the engine size?
Maxx
52 GMC Grumman Olson Kurb Side stepvan T3-8(Comet)69 GMC 1/2-ton
#196051 12/23/2005 4:33 AM
3B Offline
Hy Maxx, the number you gave us is the cylinder head casting number for a 50-52 chev. 235 hope this helps
#196052 12/23/2005 5:28 AM
Is there a site/generator that tells you what it is?
JJ
#196053 12/23/2005 6:56 AM
3B Offline
Hy CHEVYFREAK1822003, Just click on the links at the top of this sight, click on inliners, then click on casting numbers on the left of the page. Hope this helps.
#196054 12/23/2005 12:01 PM
Thanks Wrench Fetcher you say 235 ci
are you on the Island or the or the big rock
The machined boss behind the distributor is blank I put a shot of WD40 and a good cleaning it is blank this is a six cylinder single barrel updraft on a Olson Kurb-Side
Comet T3-8" GMC chassis PM 152-22, 104" wb, chassis weight, overall
length 188.25", GVW with std tires 6200 lbs (7000 with maximum tires)
Thanks for all your help
Maxx
#196055 12/24/2005 1:51 AM
3B Offline
Hy Maxx, Firstly my handle is 3B, wrench fetcher is a title they give you here. Secondly I'm in Rosedale on the "big rock"
