3 members (1955 1 Series, 2 invisible),
128
Mod | | | Forums66 Topics128,195 Posts1,057,370 Members48,469 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2005 Posts: 47 Member | | Member Joined: Dec 2005 Posts: 47 | I bought a complete front end and doors off a 51 1.5 ton and wanted to use them on my 51 half ton truck. At the time I didn't know there were wider. Can they still be used on the smaller truck or are they too wide. Anybody done it? I hope they can be used as they are in great shape. I hope start on this truck in a few months . James
Heres to us and those like us, theres darn few left.
| | | | | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | James, They would bolt to the cab, but I think it would end there. I have a 1 1/2 ton myself so I know those suckers are huge. The hood would have to be changed along with the grill...it's the whole wrap or nutin! If you did overcome ALL those obstacles, it would be, pardon my french, a bastard looking affair. Stuart | | | | | | Anonymous Unregistered | | Anonymous Unregistered | Sell them and get the fenders for a 1/2 to 1 ton and have it done right. Or, section the fenders to remove about two inches. It may give your truck a unique look. | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | If you have time to wait, those fenders should sell for more than the 1/2 Ton ones will cost to buy. That is because they are harder to find. | | | | | Joined: Nov 2005 Posts: 39 Apprentice | | Apprentice Joined: Nov 2005 Posts: 39 | atomark: You're sure about the hood???? I've got hood one from a 1/2t and hood from one that came with the next larger fendered truck and they look the same!
I want to use the one that came with the larger truck cuz it's in great shape.
Help!
1951 Chev.P.U. Streetrod-project 1951 Chev cpe 261 5-speed-50% 1953 Chev cpe 350/700-95% 1962 Chev Bubbletop 409 -75%
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | the hoods are the same, only difference is the fenders
Bill | | | | | Joined: Mar 2004 Posts: 3,068 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 3,068 | Originally posted by iowa trucks 59: Big truck fenders aren't much in demand. I have a guy in Ks that just tosses them. He's put them ebay but seldom finds a buyer. Unless your doing a big bolt theres little market for the fenders. The half and 3/4 ones are like gold here. Do save your grill as with the correct uprights the bars are the same as a pickup. Hey Jeff, I could use some big bolt body parts (say that three times really fast). Got access to anything still? I keep finding trucks but the last two were too good to scrap. I need all the sheet metal for one of my 48's, which is a 1 1/2 ton or larger, but could get by with just a clip. Scott | | | | | Joined: Apr 2002 Posts: 1,571 Shop Shark | | Shop Shark Joined: Apr 2002 Posts: 1,571 | The hoods are different...the light-duty truck hood has a rounded lower rear corners, the medium-duty truck hood comes to a point to accomodate the larger fenders. | | | | | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | This is what I do know! The hood center strip from a 1 1/2 is much longer than the pickups. The hood emblem is much larger than the pickup. Look in the parts books like CD or Carter and you will see the application ends with, I think the 3/4 ton....mucho grande Stuart | | | | | Joined: Dec 2005 Posts: 47 Member | | Member Joined: Dec 2005 Posts: 47 | Thanks for the replies. I have learned to do my research before buying next time. Since I am a pac rat, I'll hold on to them and possibly find a truck to use them on down the road. James
| | | | | Joined: Sep 2005 Posts: 30 Member | | Member Joined: Sep 2005 Posts: 30 | Originally posted by red58: the hoods are the same, only difference is the fenders
Bill You are WRONG again Bill !!! The 1 1/2 & 2 ton conventional hoods are larger than the 1/2 3/4 & 1 ton hoods. | | | | | Joined: Sep 2005 Posts: 30 Member | | Member Joined: Sep 2005 Posts: 30 | Originally posted by iowa trucks 59: Do save your grill as with the correct uprights the bars are the same as a pickup. The grill bars on the 1 1/2 & 2 ton trucks only look like the 1/2 3/4 & 1 ton bars. They are the same width... but the big truck grill bars are 1/2 " taller. | | | | | Joined: Jul 2000 Posts: 623 "MONGO" | | "MONGO" Joined: Jul 2000 Posts: 623 | Here's a pic showing the difference from the side. hoods.jpg All the front sheetmetal is bigger. The Grill bars themselves are taller but can be made to work on a half ton with the right parts, the top bar will just smile  a little. Most people won't even notice. And if you wanna see some really big sheetmetal look at what was on the really big trucks. GMC620Hood.jpg MONGO | | | | | Joined: Nov 2005 Posts: 39 Apprentice | | Apprentice Joined: Nov 2005 Posts: 39 | KCMongo: That about settles it! I've got both hoods and yer right! Photo's don't lie!
| | | | | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | I think KCMongo has been messing around in Photoshop! I put a 1/2 ton hood on my 4400 truck and it fit nicely...right into the engine compartment. Stuart | | | | | | Anonymous Unregistered | | Anonymous Unregistered | The AD hoods are the same from 1/2 ton through 1 ton to my knowledge. The 1.5 ton and larger trucks have a hood that is wider, longer and has a different contour at the back corners. | | | | | Joined: Apr 2002 Posts: 1,571 Shop Shark | | Shop Shark Joined: Apr 2002 Posts: 1,571 | Originally posted by atomarc: Look in the parts books like CD or Carter and you will see the application ends with, I think the 3/4 ton. Then the parts books are wrong (or they just don't care about 1-tons). 1/2-ton to 1-ton front sheetmetal is the same. Beds and running boards are all different lengths, but the rear fenders and tailgates are the same. Front sheetmetal gets bigger with the 1 1/2-ton trucks (for Chebby) and the 1 1/4-ton (for GMC). Originally posted by M.T.: You are WRONG again Bill !!! The 1 1/2 & 2 ton conventional hoods are larger than the 1/2 3/4 & 1 ton hoods. MT, hadn't I already said that in a more diplomatic fashion?  | | | | | Joined: Sep 2005 Posts: 30 Member | | Member Joined: Sep 2005 Posts: 30 | Originally posted by TooMany2count: MT is correct i measured the grill parts i have & they are different Diplomatic NO ! Correct YES ! I don't answer technical questions unless I am sure of the advice I am giving out. I hate to see someone get steered in the wrong direction with incorrect information. Keep the old iron goin' | | | | | Joined: Dec 2004 Posts: 452 Member | | Member Joined: Dec 2004 Posts: 452 | Even though the question seemed to be answered here, it came up yet again in newer post. I thought I would add another picture showing the difference between the little and big truck hoods. Hood halves. The big truck hood half is on the left, and although the top of the pic is cut off (I wasn't the photographer), one can see that the big truck hood is at least 6" (maybe a little more) longer than the little one.
Curt ---- 1953 Chevy 6400, 1957 Chevy 2dr Sedan --"Mediocrity is easy, the good things take time"
| | | | | Joined: Apr 2002 Posts: 1,571 Shop Shark | | Shop Shark Joined: Apr 2002 Posts: 1,571 | That link doesn't work for me. | | | | | Joined: Oct 2003 Posts: 445 Shop Shark | | Shop Shark Joined: Oct 2003 Posts: 445 | just a thought .I have a new set of front glass fenders 1/2T,47 to 55 for sale cheap.E-mail me.Just trying to help.Please don't tell me to sell them in the parts sale.I kapish.thank you :p :p
dan-pa
| | | | | Joined: Dec 2004 Posts: 452 Member | | Member Joined: Dec 2004 Posts: 452 | I fixed the link I posted above.
| | | | | Joined: Dec 2005 Posts: 2,557 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 2,557 | The grills are taller also,harder to come by. You should have no trouble getting rid of the parts.Advertise them in the swap section,ebay would be good also. 1951 3100 Chevrolet1951 Chevrolet Suburban CarryallImage"A house is built with boards and beams. A home is built with love and dreams." "Look deep before you leap !!!" / "Everything is Everything" "If I say a mouse can pull a house, hitch him up"
