0 members (), 118 guests, and 3 robots.
Topics128,196
Posts1,057,393
Members48,471
I bought a complete front end and doors off a 51 1.5 ton and wanted to use them on my 51 half ton truck. At the time I didn't know there were wider. Can they still be used on the smaller truck or are they too wide. Anybody done it? I hope they can be used as they are in great shape. I hope start on this truck in a few months .
James
Heres to us and those like us, theres darn few left.
James,
They would bolt to the cab, but I think it would end there. I have a 1 1/2 ton myself so I know those suckers are huge. The hood would have to be changed along with the grill...it's the whole wrap or nutin! If you did overcome ALL those obstacles, it would be, pardon my french, a bastard looking affair. eek
Stuart
Anonymous
Unregistered
Anonymous
Unregistered
Sell them and get the fenders for a 1/2 to 1 ton and have it done right.
Or, section the fenders to remove about two inches. It may give your truck a unique look.
If you have time to wait, those fenders should sell for more than the 1/2 Ton ones will cost to buy. That is because they are harder to find.
1951 1 Ton Completed
Apprentice
Apprentice
atomark:
You're sure about the hood???? I've got hood one from a 1/2t and hood from one that came with the next larger fendered truck and they look the same!
I want to use the one that came with the larger truck cuz it's in great shape.
Help!
1951 Chev.P.U. Streetrod-project
1951 Chev cpe 261 5-speed-50%
1953 Chev cpe 350/700-95%
1962 Chev Bubbletop 409 -75%
the hoods are the same, only difference is the fenders
Quote
Originally posted by iowa trucks 59:
Big truck fenders aren't much in demand. I have a guy in Ks that just tosses them. He's put them ebay but seldom finds a buyer. Unless your doing a big bolt theres little market for the fenders. The half and 3/4 ones are like gold here. Do save your grill as with the correct uprights the bars are the same as a pickup.
Hey Jeff,
I could use some big bolt body parts (say that three times really fast). Got access to anything still? I keep finding trucks but the last two were too good to scrap. I need all the sheet metal for one of my 48's, which is a 1 1/2 ton or larger, but could get by with just a clip.
Scott
Scott Ward
2 1948 1.5-ton Loadmasters
1 1950 3100
1 1955.1 Chevy 6500
1 1954 Chevy 6500 2-Ton
1 1955 1st Series COE 5700
1 1963 K20 (454)
1 1964 C10 (350)
1 1951 1.5-ton Dump Truck
1953 and a 1956 Ford F800
The hoods are different...the light-duty truck hood has a rounded lower rear corners, the medium-duty truck hood comes to a point to accomodate the larger fenders.
1954 GMC De Luxe COE
This is what I do know! The hood center strip from a 1 1/2 is much longer than the pickups. The hood emblem is much larger than the pickup.
Look in the parts books like CD or Carter and you will see the application ends with, I think the 3/4 ton....mucho grande smile
Stuart
Thanks for the replies. I have learned to do my research before buying next time. Since I am a pac rat, I'll hold on to them and possibly find a truck to use them on down the road.
James
Quote
You are WRONG again Bill !!!
The 1 1/2 & 2 ton conventional hoods are larger than the 1/2 3/4 & 1 ton hoods.
Quote
The grill bars on the 1 1/2 & 2 ton trucks only look like the 1/2 3/4 & 1 ton bars.
They are the same width... but the big truck grill bars are 1/2 " taller.
"MONGO"
"MONGO"
All the front sheetmetal is bigger.
The Grill bars themselves are taller but can be made to work on a half ton with the right parts, the top bar will just smile smile a little. Most people won't even notice.
And if you wanna see some really big sheetmetal look at what was on the really big trucks. GMC620Hood.jpg
MONGO
Mongo's Garage
Vintage GM Truck's & Parts
https://mongosgarage.com
Apprentice
Apprentice
KCMongo:
That about settles it! I've got both hoods and yer right! Photo's don't lie!
I think KCMongo has been messing around in Photoshop! I put a 1/2 ton hood on my 4400 truck and it fit nicely...right into the engine
compartment. grin
Stuart
Anonymous
Unregistered
Anonymous
Unregistered
The AD hoods are the same from 1/2 ton through 1 ton to my knowledge. The 1.5 ton and larger trucks have a hood that is wider, longer and has a different contour at the back corners.
Quote
Then the parts books are wrong (or they just don't care about 1-tons). 1/2-ton to 1-ton front sheetmetal is the same. Beds and running boards are all different lengths, but the rear fenders and tailgates are the same. Front sheetmetal gets bigger with the 1 1/2-ton trucks (for Chebby) and the 1 1/4-ton (for GMC).
Quote
MT, hadn't I already said that in a more diplomatic fashion? wink
Quote
Originally posted by TooMany2count:
MT is correct i measured the grill parts i have & they are different
Diplomatic NO !
Correct YES !
I don't answer technical questions unless I am sure of the advice I am giving out.
I hate to see someone get steered in the wrong direction with incorrect information.
Keep the old iron goin'
X
X Offline
Even though the question seemed to be answered here, it came up yet again in newer post. I thought I would add another picture showing the difference between the little and big truck hoods.
Hood halves.
The big truck hood half is on the left, and although the top of the pic is cut off (I wasn't the photographer), one can see that the big truck hood is at least 6" (maybe a little more) longer than the little one.
Curt
1953 Chevy 6400, 1957 Chevy 2dr Sedan
--"Mediocrity is easy, the good things take time"
That link doesn't work for me.
just a thought .I have a new set of front glass fenders 1/2T,47 to 55 for sale cheap.E-mail me.Just trying to help.Please don't tell me to sell them in the parts sale.I kapish.thank you :p :p
dan-pa
X
X Offline
I fixed the link I posted above.
Curt
The grills are taller also,harder to come by. You should have no trouble getting rid of the parts.Advertise them in the swap section,ebay would be good also.
1951 3100 Chevrolet
