3 members (MRMEROTH11, Charles in CA, 1 invisible), 152 guests, and 1 robot.
Topics128,113
Posts1,056,279
Members48,439
#19568 11/26/2004 10:21 PM
Apprentice
Apprentice
hey guys well i have a question since my book ain't here yet but how do you get those axles out of the rear end on a 1940 1/2 ton. they look like they should just slide out with a little effort but i can't get them to move.
1940 1/2 ton chevy
#19569 11/26/2004 11:53 PM
Riding in the Passing Lane
you have to pull the cover off the diff. & remove
the lock bolt & spider gear shaft. Then push the
axle in & remove the C washer. You probably beter
get the book & follow step by step.
1972 Chevy c10 Cheyenne Super
#19570 11/27/2004 2:41 AM
Justin, get/borrow a book. Go to AutoZone and look on a chevy PU book (about any year) at the differental. When you get your diff cover off you will see what it is all about. Mike
#19571 11/27/2004 5:42 PM
Apprentice
Apprentice
thanks for the help i got the gears out of it with no problem and well it came out very easy with no seriious perswation
1940 1/2 ton chevy
