5 members (UtahYork, BC59, KEVINSKI, dt235sd, 1 invisible), 94 guests, and 2 robots.
Topics128,211
Posts1,057,469
Members48,473
I have a 57 3100 with the spare tire cut-out in the drivers side rear fender. At some point in the trucks life someone has welded in a patch to fill the cut-out and of course it doesnt fit. I want to replace the entire frender with one that doesnt have the spare tire cut-out. Do they make new rear fenders without the cut-out or do I have to find a donor truck and if so what all years will work?
55 2nd series thru 66 uses the same rear fender, your better off with a used than trying a repop that is not the quality or fit of factory fenders.
jim
1955-66 will fit and yes they are making repos both in steel and fiberglass. You can by them from most companies that deal with old GM trucks.
38 original
48 panel
59 stepside
46 in the back forty
Both Chevrolet and GMC stepside rear fenders are the same from 1955-1966.
