7 members (55shaker, Nick in Manitou, Leo, 54farmtruck, Hotrod Lincoln, Bill Hanlon, 1 invisible),
108
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,211 Posts1,057,468 Members48,471 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2005 Posts: 10 New Guy | | New Guy Joined: May 2005 Posts: 10 | I have a 57 3100 with the spare tire cut-out in the drivers side rear fender. At some point in the trucks life someone has welded in a patch to fill the cut-out and of course it doesnt fit. I want to replace the entire frender with one that doesnt have the spare tire cut-out. Do they make new rear fenders without the cut-out or do I have to find a donor truck and if so what all years will work? | | | | | Joined: Oct 2002 Posts: 77 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2002 Posts: 77 | 55 2nd series thru 66 uses the same rear fender, your better off with a used than trying a repop that is not the quality or fit of factory fenders. jim | | | | | Joined: Oct 2005 Posts: 275 Shop Shark | | Shop Shark Joined: Oct 2005 Posts: 275 | 1955-66 will fit and yes they are making repos both in steel and fiberglass. You can by them from most companies that deal with old GM trucks.
38 original 48 panel 59 stepside 46 in the back forty
| | | | | Joined: Apr 2005 Posts: 313 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 313 | Both Chevrolet and GMC stepside rear fenders are the same from 1955-1966. | | |
