Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
3 members (tclederman, Bill Hanlon, Phak1), 178 guests, and 5 robots.
Topics128,288
Posts1,058,566
Members48,492
Apprentice
Apprentice
i am going to start applying the 78 gmc front axle i have to the 63 gmc.
i have the complete truck outback i would like to switch the front springs to the 78. mine are sagging bad. i heard from good source, well i think so that it is going to be vary hard to do this with the wider springs. i need more advice on this.
i am going to add power steering and disc brakes. my truck is a k20 manual. i need to add the slave cylinder. what did you fellas use for yours?
i am going to use the tilt steering column, shaft, pump and gear box. will i need the box bracket if i have the column from the 78 as well?
how hard will it be to use the 78 booster and master cylinder?
thanks ahead of time josh
V
V Offline
shouldnt be a problem just use the mounting brackets for the wide springs
Apprentice
Apprentice
well the springs are longer that is the problem. i think i have decided so far on the info i have got that i will purchase new springs.
i am really interested in knowing about the clutch master cylinder though.
V
V Offline
if you change the brackets you can put them where you need them
Apprentice
Apprentice
the trans crossmeber is preventing a proper placement. i am just going to get new springs for the front.
i need help with from someone that has done this already for specifics on brake lines and prop. vbalve placement, clutch and brake master cyl. placement.
Apprentice
Apprentice
any one have any insight?
