4 members (TUTS 59, Shof, Ponchogl, Jon G), 172 guests, and 3 robots.
Topics128,094
Posts1,056,157
Members48,436
#19535 01/16/2002 10:37 PM
Oly
Offline
This 45 GMC COE has not had an air breather on it since I got it in 80. It is missing the hose, or what ever it was, that comes down from the breather up front to the carb, which is an updraft Zenith. What can I use for this purpose? I has to be heat resistant and flexable to get to the carb. The distance will be two plus feet in length.
Oly in Oregon
Rest in Peace
1945 GMC COE Victory Truck
1953 Willys CJ3B
1955 Chevy 1st series 3/4-ton
1958 WIFE Last series
Never say "Whoa" in a mud hole
#19536 01/17/2002 1:17 AM
If you need a original one go over to swap meet and email me. I have the entire assembly if you need it. Thanks.......
It's what you learn after you know it all that counts.......
#19537 01/17/2002 4:41 AM
If that doesn't work try VW heater box hose...It's thin metal and it's really flexable. It's also really cheap. It's the stuff used to run from the fan shroud to the tin around the engine.
Attitude - The difference between an adventure and an ordeal!
Deja Moo - The feeling you've heard this bull**** before!
'63 Chev Fleetside Longbox 'Rusto-rod' 'Big Red'
'69 or'70 or ? Mantaray DuneBuggy
