3 members (baldeagle, D B Cooper, 1 invisible),
101
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,094 Posts1,056,064 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#19535 01/16/2002 10:37 PM | Joined: Mar 2001 Posts: 327 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Mar 2001 Posts: 327 | This 45 GMC COE has not had an air breather on it since I got it in 80. It is missing the hose, or what ever it was, that comes down from the breather up front to the carb, which is an updraft Zenith. What can I use for this purpose? I has to be heat resistant and flexable to get to the carb. The distance will be two plus feet in length.
Oly in Oregon Rest in Peace1945 GMC COE Victory Truck 1953 Willys CJ3B 1955 Chevy 1st series 3/4-ton 1958 WIFE Last series Never say "Whoa" in a mud hole
#19536 01/17/2002 1:17 AM | Joined: Jan 2002 Posts: 25 Member | | Member Joined: Jan 2002 Posts: 25 | If you need a original one go over to swap meet and email me. I have the entire assembly if you need it. Thanks.......
It's what you learn after you know it all that counts.......
#19537 01/17/2002 4:41 AM | Joined: Feb 2001 Posts: 198 Shop Shark | | Shop Shark Joined: Feb 2001 Posts: 198 | If that doesn't work try VW heater box hose...It's thin metal and it's really flexable. It's also really cheap. It's the stuff used to run from the fan shroud to the tin around the engine.
Attitude - The difference between an adventure and an ordeal! Deja Moo - The feeling you've heard this bull**** before! '63 Chev Fleetside Longbox 'Rusto-rod' 'Big Red' '69 or'70 or ? Mantaray DuneBuggy
