1 members (Leo), 104 guests, and 1 robot.
Topics128,049
Posts1,055,743
#195142 12/09/2005 2:14 PM
Does anyone know of a web site for head casting numbers. I have a head # 3836850 which I believe is a 1958 261.
Jim Carter lists the numbers in a technical article on his website (he does not allow links to the articles). He lists your number as being a 261 head from any year that a 261 was made (1954-1962).
Yes, my lists show the head as a 261. Only other clue would be the date code to narrow down the year.
1946 1/2-Ton Chevy
Thanks guys
Riding in the Passing Lane
Was that head used on 235 also. If I have a engine with that head & its never been messed with than I can assume its a 261?
1972 Chevy c10 Cheyenne Super
An 850 head is for a 261 engine. A 848 came from a 235 engine. When I put a 261 back together out of 2, one of them had a 848 head on it. The previous owner wanted to increase compression by using the 235 head on the 261. Instead the water passages didn't mate and caused overheating and engine failure.
Check the engine numbers and specs with your machinist before you rebuild.
41 Chev 2dr coupe
51 3100 w/a 261
11 Camaro RS ragtop
