| | | Forums66 Topics128,055 Posts1,055,785 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2005 Posts: 67 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2005 Posts: 67 | On my 53 3/4, there is wire which was poking out a rubber grommet in the centre of the roof. It looks origional, but i haven't seen any other trucks with them installed. Brendon | | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy again Brendon, I see your now proclaiming to the world that you have a 53 3/4 ton, does that mean the what is it question is answered to your satisfaction? As for the interior light, all of my trucks have it in the back of the cab behind your head. Is there a hole in the roof, could there have been a spotlight, or a rotating beacon mounted on the roof? | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | taxi?  coulda been any kind of emergency or service vehicle that some po added the light for - or even a spotlight [for 'roo huntin] - not any type of factory thing is why you've never seen it - how many previous owners has the truck had? Bill | | | | | Joined: Nov 2005 Posts: 67 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2005 Posts: 67 | Yes 3B, i have it on good authority that my truck is a 3/4 (you Guys). This was an external thing, as there was no light attached to the wire. The wiring was of the same vintage as the rest of the wiring and was concealed under the roof lining. unfortunately i have no idea who even owned my truck before me. I believe he had passed away. As for roo huntin, i'm sure the truck seen some of that action. As an emergency vehicle, i very much doubt that. Brendon | | | | | Joined: Nov 2005 Posts: 67 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2005 Posts: 67 | | | | | | Joined: Nov 2005 Posts: 67 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2005 Posts: 67 | Nope that's wrong. i hate computers. lets try that again. Http://community.webshots/myphotos?action=viewAllphotos&albumID=510494948&security=RRtcCO sorry | | | | | Joined: Mar 2004 Posts: 3,068 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 3,068 | My 48 had a clearance light bar that ran across the roof and was powered by a single wire through the roof. The lights weren't mounted to the cab but rather to a bar and some brackets attached to the rain gutter on each side of the truck. I'm sure it's some aftermarket add-on done early in your trucks life. Scott | | | | | Joined: Nov 2005 Posts: 67 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2005 Posts: 67 | | | |
