3 members (hardshell, FishinToms53, lumbersawyer), 45 guests, and 3 robots.
Topics128,030
Posts1,055,428
Members48,422
#194999 12/04/2005 6:31 PM
Apprentice
Apprentice
hello stovebolters;
I've just joined your forum and look forward to sharing info.My name is Ed,and I am currently restoring a '59 GMC 1/2 ton fleetside longbox model 9324(canadian built).This truck is going to be a driver,and is being mounted on a 1985 gmc 1/2 ton 4x4 chassis that has been shortened to the correct wheelbase.The chassis is fitted with a 6.2 litre diesel engine to which I am adding a turbocharger and intercooler.It also features a muncie 465 4 speed, 4" suspension lift,hydroboost braking, and all controls are being modernised to the '85 standard.
One item I am looking for info on is deluxe heater cores,mine is junk and I'm not about to spend $200 for a repro,I will probably adapt a similar readily available core,just wondering if anyone knows of a close match?
Looking forward to chatting with you guys.
ed
#195000 12/04/2005 6:40 PM
V
V Offline
Welcome!!!
#195001 12/04/2005 9:16 PM
Sounds like an interesting project. I like the idea of an old body on a later model 4x4 chassis. I might go that route myself whenever I find one. Good luck with it, sorry I can't really help with your question.
Rob
#195002 12/05/2005 5:39 PM
Welcome Ed,
This guy has a yard full of trucks and could probably fix you up with a good used one. No ideas on a close match for the round core though.
http://www.scottssupertrucks.com/
Curt B.
You Tube
#195003 12/05/2005 11:50 PM
Apprentice
Apprentice
thanks.I've got the rectangular core,I think it's a deluxe heater,takes in outside air.
ed
#195004 12/05/2005 11:56 PM
Ed,
I don't to be the devils advocate, but it sounds like you haven't spared much money on the project so far....wouldn't a nice new heater core be a drop in the bucket. I will bet it gets REAL cold in your neck of the woods this time of the year! smile
Stuart
#195005 12/06/2005 12:01 AM
Apprentice
Apprentice
Yup I'm going to go with a new core,not worth screwing with any half-rotten scrap.Just don't want to pay the hosing for the OEM one,seems only one place makes them,and they want around 2 hun + a 50 buck core charge.I'll get a similar new core for about 50 bucks and adapt the pipes as required,nothing a little soldering won't fix.Just wondering if anyone else has done this.
thanks
ed
#195006 12/06/2005 2:29 AM
around here any rad shop can obtain most any size core and simply use your tanks on it if they're not rotten [only reason the repro places charge cores is for the tanks] - you may be able to do that yourself, but always nice to have someone else to cuss at if it leaks! I've had 2 different cores redone, don't remember the price, but waaay under 250!
#195007 12/06/2005 3:37 AM
Apprentice
Apprentice
Thanks for the tip,Bill.Someone has already cobbled the core I have,it is not an original.Not a very pretty job,either.
ed
