7 members (MickeyP, RoadsScholar, Gdads51, 1955 1 Series, thekid1950, tclederman, klhansen), 117 guests, and 1 robot.
Topics128,081
Posts1,056,068
Members48,433
During a recent R&R of the cylinder head in my '53, the factory mechanical sending unit line separated itself from the water jacket fitting. Are replacement ones available anywhere, or is this going to be a search for a good used one?
R.F.
If you click on the American Classic icon at the top of the page you will find they have new complete gauges for around $50.00...can't beat that with a BFH!
Stuart
Can't beat it with a hammer, but I can by a buck! Just found new ones at Jim Carters for $49! Thanks for the help though.
R.F.
I am certainly not one to preach poor consumerism, but if you think the question you posted and the answer that was given was worth a buck, maybe you should consider American Classic....they are a sponsor of this site. smile
Stuart
No, I was just pointing out the fact that I had stumbled across Jim Carter prior to your response. Had nothing to do with pricing, just a response to the BFH comment.
but remember Stuart, Carter is offering a 20% off to 'bolters only right now, which makes it better by 10$ grin
Bill,
You are right! $10 might be enough incentive for me too.
Stuart
Quote
Actually, $10.80!
Apprentice
Apprentice
$ 9.80 ! actually ;-)
Later JJ and 4
Keep the shiney side up
Junior Member
Junior Member
If you are ever going to a small block (which doesn't sound likley too soon due to your R&R of the 6 cylinder head) you might get a guage with a longer tube due to the up front location of the sensor. Just thought I'd mention it - I drove for awhile with the sensor hanging in air untill I popped for a new gauge/sender with a longer tube for the V8.
I know this will upset someone,but at Wal-mart or big lots you can get a Cheap set of gauges for $9.95.That oil ,amp, temp.There Cheap but they work fine.An they don't look bad :p :p
dan-pa
